2020 LDU Performance Inverter Overcurrent Errors
Posted: Wed Sep 21, 2022 3:22 pm
Working on bringing a 2020 Model X Performance back to life. Was hit in the rear but rear DU/Inverter casing was not damaged externally.
Unfortunately butting up against over current errors in inverter. IGBT blowout as referenced in another thread? No sign of coolant intrusion at HV terminals or speed sensor. Any help from the experts here would be appreciated.
I've attached a picture of errors. If anyone has a compatible replacement inverter, DU , or knows of someone who can repair it would be appreciated.
Thanks. Josh in FL
Thanks. Josh in FL
