Mitsubishi AWD Project
Posted: Sat Aug 27, 2022 5:46 am
Hello All,
I currently have an AWD Mitsubishi that I am looking to convert. Currently, the vehicle is producing around 300hp and 265 lb ft tq. The easiest option would be to leave all of the running gear and use an electric motor to drive everything, but I'm not sure of what potential options are there. Any suggestions? I'd like to try and make at least the same power. I have looked at the GS450h work and EM57. I have immediate access to a complete EM57 for cheap; but I'm not certain that even with more power driven to it, it would meet what I'm looking for (unless I ran two together somehow).
Open to any help, questions, or suggestions!
edit
I've decided to start by purchasing an EM57 complete motor, 160kW inverter, and charger. I think my first goal will be to play around and figure everything out and then do a FWD conversion with 24kWh of Leaf modules; just to figure it all out and get it running. Once that's done, I'll look at upgrading things and maybe down the road dropping in a rear unit.
edit
