Suggestion for "iacmax" parameter
Posted: Tue Jul 26, 2022 6:30 pm
I am doing some tuning and I notice that there is currently no spot value for instantaneous AC current. There are a couple of approximations in the form of i1rms and i2rms, but I think it would be very useful to have an instantaneous value for the peak AC current. This can be calculated quite easily as follows:
The result of this calculation is demonstrated in the attached chart. I would suggest that GetIlMax could be replaced with this calculation as this will return what the max phase current *will* be, even if that peak hasn't been reached yet in any particular phase. This might also reduce oscillation when derating on AC current.
On a related note, I'm confused by why a SVM offset calculation is used in GetIlMax. As far as I know, SVM offset shouldn't impact current readings.
i3 = - i1 - i2
imax = sqrt(i1 * i1 + i2 * i2 + i3 * i3) / sqrt (1.5)
