Prius GEN3 Inverter @ 48V?
Posted: Mon Jul 18, 2022 1:32 am
I am very curious to learn if the Prius Gen3 Inverter can operate on a 48v system, and if so, what can it do with a 48v input? Will the Boost circuit operate at all with a 48v input? If so, what would be its max output capabilities?
Does the boost circuit only exist on the output for one motor?
What are the limitations with the Gen3 Inverter?
Minimum usable input voltage?
Max Kw output?
Max Amp throughput?
Any clarification of these details would be greatly appreciated!
Thanx!
Max Kw output?
Max Amp throughput?
Thanx!
