Wanted - nissan leaf 110kw,160kw Inverter Logic Board
Letins
Post by Letins »
I buy Nissan leaf inverter 110kw,160kw ome logic board only...
Letins
Re: Wanted - nissan leaf 110kw,160kw Inverter Logic Board
Post by Letins »
I'm still looking...
Romale
Has thanked: 214 times
Been thanked: 49 times
Post by Romale »
Letins wrote: Wed Nov 23, 2022 10:30 am I'm still looking...
buy a v3 board here in the store and connect it to the driver board of your inverter yourself. there is no ready-made adapter board for this. dolgo for nissan leaf gen2 .
evil neodymium :twisted:
Romale
Post by Romale »
in fact, this board allows you to get 160+ kW even with gen2 (I personally have achieved this more than once)
Has thanked: 57 times
Been thanked: 176 times
Romale wrote: Thu Dec 08, 2022 5:59 pm buy a v3 board here in the store and connect it to the driver board of your inverter yourself. there is no ready-made adapter board for this. dolgo for nissan leaf gen2 .
He’s looking for the OEM board.
Romale wrote: Thu Dec 08, 2022 6:00 pm in fact, this board allows you to get 160+ kW even with gen2 (I personally have achieved this more than once)
160kw out of the gen 2????? Do you have parameters posted anywhere? I thought 140kw was max
Zapatero
Has thanked: 25 times
Been thanked: 39 times
Post by Zapatero »
I maxed the gen2 out at exactly 136 kW
Romale
Post by Romale »
Bratitude wrote: Mon Dec 12, 2022 4:32 pm 160kw out of the gen 2????? Do you have parameters posted anywhere? I thought 140kw was max
143 kW I received is recorded on video and this is with a very weak battery. the voltage drawdown was below 323 volts, dc current is 445 amps peak. Later I used a more powerful battery and the voltage drawdown was up to 365 volts (unfortunately the video was not filmed), but the wattmeter managed to record more than 165 kW with gen 2 and the v3 board.
143 kw I showed in my buggy topic
Romale wrote: Mon Dec 12, 2022 7:55 pm 143 kW I received is recorded on video and this is with a very weak battery. the voltage drawdown was below 323 volts, dc current is 445 amps peak. Later I used a more powerful battery and the voltage drawdown was up to 365 volts (unfortunately the video was not filmed), but the wattmeter managed to record more than 165 kW with gen 2 and the v3 board.
crazy! what are your parameters? mind sharing them?
Zapatero
Post by Zapatero »
My inverter kept shutting down if I pushed the pedal hard... I never could set throtcur above 7.5! The current below 2000 rpm was just too high and it had to deliver it for too long. Maybe the weight of the car is the factor here. The lighter car is much faster out of the zone where the Amps are extreme.
Romale
Post by Romale »
Bratitude wrote: Mon Dec 12, 2022 11:07 pm crazy! what are your parameters? mind sharing them?
I used publicly available parameters, the same as Johu's on his tauran, it's just important to have a good battery so that there is no voltage drawdown. even before the OI community, I tested gen2 with a 500 volt battery and it worked fine. therefore, you can get even more power. Perhaps the reason really is the mass of transport.
par.Buggy.5.25.json
(1.49 KiB) Downloaded 39 times
