/* Shut down PWM on zero voltage request */
if (0 == amp || 0 == dir)
timer_disable_break_main_output(PWM_TIMER);
However there is a slightly alarming note on the wiki.
If they are both low, no current is fed to the motor making this essentially the neutral position.
Correction, this will not be a neutral position. Rather, it will be almost parking, if you turn on neutral at speed, there will be a very hard stop regen!
Please can someone confirm which is correct. I'm happy to update the wiki to remove the contradiction.
Re: Behaviour in neutral
Posted: Fri Jul 01, 2022 1:10 pm
by Peter
Hi Charlie. I will do a test this evening by selecting neutral when rolling with no throttle and again with a little throttle to see what happens.
For reference I have regen set up so it is only working when brake is pressed, so backing off throttle gives no regen, that way I can coast when off throttle.
Posted: Fri Jul 01, 2022 2:37 pm
The behaviour is different in sine and FOC firmware. To be honest I never tested the FOC setup but I believe it is buggy due to what I see in the code and what you found on the wiki.
On the sine firmware it should work alright.
Posted: Fri Jul 01, 2022 8:01 pm
by Peter
Tried selecting neutral whilst rolling with no throttle applied and did not regen, just coasted. Same with small amount of throttle. Hope that helps.
Posted: Sat Jul 02, 2022 12:05 am
by catphish
Thanks both. I also had an opportunity to test this today for myself and it seems (at least with sine firmware) I also get coasting.
Posted: Sat Jul 02, 2022 10:37 pm
by Romale
catphish wrote: ↑Thu Jun 30, 2022 11:27 pm
fok firmware we get a hard stop
I would be very happy to have a roll on the neutral with the foc firmware, but I did not find what setting to apply so that this became possible.
Posted: Mon Jul 04, 2022 9:22 pm
by geduxaz
What i have tested, with FOC it hits hard. i broke CV joint.
Posted: Wed Jul 06, 2022 6:22 pm
by catphish
geduxaz wrote: ↑Mon Jul 04, 2022 9:22 pm
Ouch! I'm very glad this works better in the sine version!
Posted: Thu Jul 07, 2022 7:25 pm
by Romale
johu wrote: ↑Fri Jul 01, 2022 2:37 pm
what solution can be applied so that the neutral on the foc firmware also gives a free roll?
Posted: Thu Jul 07, 2022 8:18 pm
Some rework in pwmgeneration_foc.cpp. For now, just avoid neutral
Posted: Sun Jul 10, 2022 3:20 pm
by js1tr3
it looks like this also affects manual mode. which might explain why I can't get any PWM output when testing in manual mode. I will try connecting the forward signal and report back.
Posted: Mon Jul 11, 2022 6:15 am
Oh indeed, in manual mode you also need to select a direction
Posted: Wed Jul 13, 2022 6:19 pm
Here is a version you can try that should solve neutral behaviour.
int dir = frqFiltered > FP_FROMINT(10) ? Encoder::GetRotorDirection() : Param::GetInt(Param::dir);
so when the rotor is moving it will use the actual rotor direction as direction, when stationary (frq < 10Hz) it will use the intended direction. Please check if it works.
Posted: Thu Jul 28, 2022 11:14 am
by Romale
johu wrote: ↑Wed Jul 13, 2022 6:19 pm
It looks like I have the worst memory chip for wifi. it is constantly hanging at this stage
please, can I have a .hex file?
Posted: Sat Jul 30, 2022 5:21 pm
I have added it to the post above
Posted: Sat Jul 30, 2022 7:39 pm
by Romale
johu wrote: ↑Sat Jul 30, 2022 5:21 pm
thank you very much.
tomorrow I will definitely check on the buggy and report the results!
Posted: Sun Jul 31, 2022 5:11 pm
by Romale
I have not tried high speed, but up to 35km/h turning on the neutral gives a free roll!
it works!
thank you so much for solving this problem.
if you turn it forward again in motion, it does not react to the gas pedal until I stop, then it can go again.
Posted: Sun Jul 31, 2022 6:48 pm
Great!
Yes it is programmed like that. You can raise dirchangerpm to overcome. But it will allow you to switch to reverse at speed. Not quite sure what happens then
Posted: Sun Jul 31, 2022 6:51 pm
by Romale
johu wrote: ↑Sun Jul 31, 2022 6:48 pm
ok. I will definitely test it.
I tested 500 and 1000. it works great. also, if you turn on the neutral at speed and then "forward", the pedal control returns after the speed drops to the specified value. left 500rpm. I liked it very much.
