SDU wiring Brake Transolver
Posted: Tue May 10, 2022 7:49 pm
by Colin0999
Need assistance wiring up my Tesla SDU. The wiring diagram mentions "brake transolver +5v" for pin 18 of the 20 pin Molex connector. Could someone please explain what this is and what it does. I was unable to find anything searching the forums. Thanks!
Re: SDU wiring Brake Transolver
Posted: Thu May 12, 2022 11:42 pm
by EV_Builder
Are you wireing OEM or are you wireing OI?
Posted: Fri May 13, 2022 12:53 am
by Colin0999
OI.. thanks
Re: SDU wiring Brake Transolver  [SOLVED]
Posted: Fri May 13, 2022 1:24 am
by EV_Builder
ok the brake input is an analog input to know how "hard" you are pressing the brake pedal.
Its not mandatory and config dependant but if you can generate this signal it will mean that regen is applied in accordance with that signal.
Posted: Fri May 13, 2022 3:26 pm
by Colin0999
Awesome. Thanks!
