HV Contactors wanted
Posted: Tue May 10, 2022 10:35 am
by RetroZero
Looking for 4 high voltage contactors for my project. 3 to disconnect Mg1 and 1 to bypass converter.
Re: HV Contactors wanted
Posted: Tue May 10, 2022 10:37 am
by m.art.y
Do you know what model? Are they suitable from OEM battery packs?
Posted: Tue May 10, 2022 4:25 pm
by jnsaff
I still have some contactors. I can definitely find about 10. I'll check what I have in garage and let you know in PM. That is the big chunky ones.
I also have tons of 100A contactors which don't have economizers. Can be had for very cheap if anyone is interested. I'll create a garage spring clean thread separately.
Posted: Tue May 10, 2022 8:26 pm
by RetroZero
I would like it to be as OEM as possible, with economisers if possible. I am dealing with German TUV equivalent ×10. Needs to be switched from 12vdc too. I have seen ones one the net and after going into specs, noticed they switched with 48vdc, not what I was looking for. Thanks for the replies so far.
Posted: Wed May 11, 2022 12:13 pm
by jnsaff
I have 4 Gigavac GX14BBB-1 contactors here. You can see datasheet
https://www.gigavac.com/sites/default/f ... t/gx14.pdf they are new. 40EUR each, shipping to France 20EUR for the lot.
There are also I think about 8 Kilovac EV200's, those are used however. 30EUR each.
https://www.te.com/commerce/DocumentDel ... ng=English
Posted: Wed May 11, 2022 2:45 pm
by RetroZero
Thanks, will PM you then
Re: HV Contactors wanted [SOLD]
Posted: Sun May 15, 2022 8:31 pm
by RetroZero
Don't know what happened, but Alibaba order just rocked up on my doorstep after a month...
Administrators can put this into solved status. Thanks for the offers, and sorry for the bother.
