Prius Gen 3 - What to Grab?
Posted: Sun May 01, 2022 2:14 am
Context:
My local junkyard, that as a rule never takes EV or hybrid vehicles, very rarely ends up with some when they buy a bundle of, say, 20 vehicles.
Probably the battery is gone (and with it the contactors and safety plug) as part of the yard-prep before it ever showed up.
But, presumably what remains is the rest of a Prius Gen 3.
Now, I already have a Prius Gen 2 inverter (which, I may just throw out, as I'm stumped on why it's not working)... so I figure if it's cheap I might grab the inverter just because (they don't even have a price for it, as they don't bring in hybrids).
I'm converting a 1970 Opel GT (small Corvette-like 2-seater).
Mission:
What should I grab?
I was thinking:
- Inverter (if cheap), and surrounding harness/pump/lines
- Contactors/Safety Plug (if not stripped with battery)
- Throttle pedal
- Steering column (for the world's easiest power steering upgrade, common even for ICE restorations)
- Maybe the air conditioner system? I know the Gen 2 has a 3ph inverter specifically for the A/C, and I would have to add this to my car. So, I should mostly be ready for it, and should be agnostic about what powers it, right? So, condensor, evaporator, pump, motor, harness? Or is that dumb to try to bodge into a classic car? Or is there a heating/cooling all-together system from a different vehicle I should be picking up instead?
- What else? What am I missing? What should I grab from it?
Mission:
What should I grab?
I was thinking:
- Throttle pedal
