Best EV motor for direct drive?
Posted: Fri Apr 01, 2022 7:23 am
what's up guys im new here so Im not sure if im posting in the right spot but, I was looking at some in-wheel hub motors that seemed promising to a guy without any bigger tools like a lift or pneumatics. problem was the top speed was typically around 65mph, which just won't cut it.
So I was dabbling with the idea of direct drive (maybe to the pumpkin) and was wondering if anyones done it with satisfying results, Like 80-100mph or so? if so what motor did you use?
