GS450 (L110) vs L210 selection advice
Posted: Fri Feb 18, 2022 10:13 pm
by krita
Hi All,
Been lurking here for a year or so, looking at converting a hilux work ute to full EV. I'm trying to decide if I'll require the GS450h 2 speed transmission over the L210(crown hybrid) single speed due to weight.
Currently it tips the scales at about 2200kg full of regular tools and materials and i assume ill be adding 300ish kg when conversion is complete. I drive up and down hills daily of 19% gradient to and from my house so would like to maintain ~60km/h on those but one of our highways has a hilly section of 28% gradient in a 100km/h zone. The current petrol V6 has 343Nm torque and doesn't struggle to pull the weight up the hills but obviously has a gearbox for assistance.
Diff ratio is 3.583:1 with 235/55R17 tires.
Any opinions would be greatly appreciated as i want to do it right the first time
Re: GS450 (L110) vs L210 selection advice
Posted: Wed Feb 23, 2022 12:27 pm
by bobby_come_lately
Based on Paul Compton's maths I think you might struggle to get the higher speeds with that diff setup, though I don't think anyone has tested it yet. I'm using the L210 in my new project and will likely look for a diff with a less than 3:1 ratio to swap in.
Posted: Sat Feb 26, 2022 9:34 pm
by krita
Can I ask where these calculations are to have a look at?
Gearing looks ok for speed and rpm requirements through an excel spreadsheet I made, unless I missed something.
L110 110km/hr @ 5800 RPM in HI MG1 Speed
L110 110km/hr @ 11850 RPM IN LOW MG1 Speed
I cant find the reduction ratio between MG1 and MG2 and assume these is no more reduction between MG1 and the shift assembly of the transmission.
L210 110hm/hr @ 10100RPM MG2 Speed
L210 110hm/hr @ 7900RPM MG1 Speed
Posted: Fri Apr 07, 2023 9:32 pm
by Jacobsmess
Hi, sorry to resurrect, where did you get those RPM ratings for l210? I'm looking at using it with my van. Cheers
Posted: Thu Apr 20, 2023 10:41 am
by krita
It was using mostly forum data I found about the transmission ratios along with items known like diff ratio and rolling diameter or tyres. I'm not sure my numbers were accurate as at that point.
