EVGT - Another Z3-based project
Posted: Fri Jan 21, 2022 1:01 pm
by bobby_come_lately
I enjoyed the first (ongoing) project so much, I'm starting a new one. BMW Z3 + Zombieverter + IS300h gearbox & inverter (not yet supported, I know) + Tribute Automotive GT body conversion.
Re: EVGT - Another Z3-based project
Posted: Wed Jan 26, 2022 3:24 pm
Posted: Sat Jan 29, 2022 5:15 pm
Posted: Sat Jan 29, 2022 10:21 pm
Fantastic, very inspiring for my upcoming Audi E2 series :)
Posted: Sun Jan 30, 2022 7:22 am
That sounds interesting. Bet Fiachra will be following that one!
Posted: Sun Jan 30, 2022 9:58 am
by crasbe
As I can't add pictures to YouTube comments, here's a picture with the drain plug on the side of the engine.
When tightening it needs a new washer and should be tightened to 25Nm. In case anyone buys the engine, it would be a nasty spot for a leak :D
Z3 M52 Drain Plug.png (15.1 KiB) Viewed 5355 times
Posted: Wed Feb 02, 2022 7:57 pm
crasbe wrote: Sun Jan 30, 2022 9:58 am As I can't add pictures to YouTube comments, here's a picture with the drain plug on the side of the engine.
Ah brilliant - thank you!
Posted: Wed Feb 02, 2022 7:58 pm
Little vid on the vacuum pump and PAS pump that arrived this week. Nothing new for you guys I'm sure. But question: am I the first one to try the Ford Focus PAS pump? Or am I treading old ground?
Posted: Fri Feb 11, 2022 3:28 pm
Progress. Not as much as I would like, but progress nonetheless.
Posted: Sat Feb 19, 2022 4:57 pm
Got some time in the workshop this week and my second BMW Z3 is now de-ICEd.
Posted: Sat Feb 19, 2022 7:36 pm
Might be worthwhile reusing parts of the engine wiring loom and placing your VCU into the ECUs enclosure. So many signals are there! That said, you're using ZombieVerter which probably won't fit.
How much would I NOT like to work on that other car :shock:
Posted: Wed Feb 23, 2022 12:23 pm
johu wrote: Sat Feb 19, 2022 7:36 pm Might be worthwhile reusing parts of the engine wiring loom and placing your VCU into the ECUs enclosure. So many signals are there! That said, you're using ZombieVerter which probably won't fit.
That's what I did last time. Tempted to put the Zombieverter inside the cabin this time, if only for good WiFi reception! There are two wiring channels that run from that box into the cabin so that's easy enough. Then I can run out from there to the inverter etc.
Posted: Tue Mar 08, 2022 7:53 am
Post another video on this project last week - nothing very EV related but some very soggy carpets.
Posted: Thu Aug 25, 2022 10:04 pm
