Testing SDU inverter
Posted: Thu Jan 20, 2022 8:16 pm
by Peter
Hi Forum. Can the inverter (with Openinverter control board) be run without encoder for bench testing using a small 3 phase induction motor driven fan as load ?
Re: Testing SDU inverter
Posted: Fri Jan 21, 2022 12:10 am
by Isaac96
Absolutely! Just use 'start 2' to get into manual mode, then change fslipspnt, fweak, and ampnom as needed.
You'll probably want to follow this guide in the wiki:
https://openinverter.org/wiki/Schematic ... _the_motor
Just be careful to avoid overheating the inverter -- apparently they don't really like running without coolant because the thermal mass is low.
