Two leaf motors (4x4)
Posted: Sat Jan 08, 2022 2:43 pm
by Renegate2020
I would like to implement the scheme of operation of two Leaf engines (4x4). Is it possible? How to make two motors work at the same time? Do you need some kind of matching scheme?
Re: Two leaf motors (4x4)
Posted: Sat Jan 08, 2022 5:18 pm
by Bratitude
With oi, just link the 2 boards via can and map the throttle controls
Posted: Sat Jan 08, 2022 5:42 pm
Renegate2020 wrote: ↑Sat Jan 08, 2022 2:43 pm
You can use each channel from Prius throttle for its own inverter brain. First you make the rear drive come to torque. Then experiment when to apply the front one too. Should also set a deadband for regen too, so you dont lock up an axle...
You would not need two brake switches because that should be one action for both OIs.
Posted: Sat Jan 08, 2022 8:13 pm
by Renegate2020
One engine with regeneration, the other without regeneration?
Posted: Sat Jan 08, 2022 11:21 pm
Renegate2020 wrote: ↑Sat Jan 08, 2022 8:13 pm
No, deadband means you need to taper regen down at small RPM before you come to a complete stop. You need to set that in both motors so no regen at low RPM that could cause your wheels to lock.
Posted: Sun Jan 09, 2022 4:01 am
by Bratitude
arber333 wrote: ↑Sat Jan 08, 2022 5:42 pm
while this dose work and is quite simple, there’s no redundancy for each controller!
Posted: Sun Jan 09, 2022 7:52 am
2x controllers ARE redundancy in your case. And Johannes put in code a safety so that too fast throttle advance is ignored.
I agree if you use CAN bus throttle you can slave one inverter to the other and they will be perfectly synced.
Posted: Sun Jan 09, 2022 1:05 pm
by Renegate2020
CAN I do not use
