Page 1 of 1
BMW i3 PDC module pinout
Posted: Wed Jan 05, 2022 10:38 am
by filipe210
Hi, I want to add the front parking sensors on my BMW i3. Does anyone know the pinout of the PDC module?
I already have the colors code of the wires and sensors, just need to know the pinout numbers of the module.
Re: BMW i3 PDC module pinout
Posted: Tue Jan 11, 2022 1:38 pm
by cloudy
Posted: Tue Jan 18, 2022 2:32 pm
by filipe210
Hi Cloudy, thanks for the answer
Do you know if it is this pinout sequence?
Thank you
Posted: Tue Jan 18, 2022 2:51 pm
by cloudy
not sure sorry - you should be able to trace the ground easily to confirm pin 10. Canbus will probably be twisted together (pin 6/15) so that might help also...
Posted: Wed Jan 19, 2022 7:27 am
by filipe210
Tks Cloudy, I'll share what I find later
Posted: Wed Jan 19, 2022 5:53 pm
by Doig5710
If you have the loom half of the plug pull it apart, it'd almost guarantee it was numbered somewhere on the plug, usually really small though
Posted: Wed Jan 19, 2022 8:13 pm
by crasbe
Usually there are very small numbers in the socket as well.
Posted: Mon Jan 24, 2022 1:49 pm
by filipe210
Thanks crasbe I found it
![Image]()
