Page 5 of 16
Re: Outlander VCU - Rear inverter, Charger and BMS
Posted: Fri Apr 29, 2022 6:38 am
@aot93 What is the reason you use 2032 battery on the dash control module? Do you power it for sleep mode?
What if i just ommit it and power the dash from enable (engine running) signal?
tnx
Posted: Fri Apr 29, 2022 8:44 am
by aot93
It is for the real time clock.
The mini has no clock as standard so I thought it was nice to add one.
Posted: Fri Apr 29, 2022 9:32 am
aot93 wrote: ↑Fri Apr 29, 2022 8:44 am
Hm... could we use that RTC to postpone charging after cable has been connected eg. 3hrs later?
Posted: Fri Apr 29, 2022 10:30 am
by aot93
This is on my to-do list yes, create a charge timer and scheduler.
The difficult bit will be in creating the UI I think., I think it would need a web interface..another one on the to do list!
Posted: Fri Apr 29, 2022 1:11 pm
aot93 wrote: ↑Fri Apr 29, 2022 10:30 am
When i put 3 chargers together i thought about using them separately. So i devised a simple UI. 3 LEDs and a single button. When i cycled the button LEDs would com on in sequence and so did charger CAN IDs.
Maybe you could set something as simple or you could have display tell you charging start time
Posted: Mon May 30, 2022 10:01 pm
by Drivelafrance
This thread is fascinating. I've just started on my journey and am looking at a very similar build transplanting outlander gear into a fwd car. Quick question at a high level. My first big purchase has been a 12kw battery pack from a 330e. Does anyone foresee issues using this higher voltage battery with the outlander rear inverter and charger?
Posted: Tue May 31, 2022 8:37 am
by marcexec
I think the Outlander is just voltage limited because of space - the components are properly rated for 96s according to Arber:
https://openinverter.org/forum/viewtopi ... der#p37663
Posted: Tue May 31, 2022 2:01 pm
All Outlander components can work with 96S. Apart from AC compressor which can work from 104S!
Posted: Tue May 31, 2022 7:58 pm
by Drivelafrance
This is great news!
Thanks for the confirmation and the prompt reply!
Cheers
Posted: Mon Jul 18, 2022 11:59 am
by GeneralScanner
aot93 This is amazing work!
Would you still have any of the PCBs available?
Many thanks G
Posted: Mon Jul 18, 2022 10:18 pm
by aot93
Sorry I'm all out of boards.
Posted: Wed Jul 20, 2022 1:19 pm
GeneralScanner wrote: ↑Mon Jul 18, 2022 11:59 am
Many thanks G
I may have some unpopulated left. Which ones do you need? And where are you at?
Posted: Thu Jul 21, 2022 11:21 am
by aot93
Looks like the teensy's have moved to unobtainium for a while at least.
Posted: Thu Jul 21, 2022 11:44 am
aot93 wrote: ↑Thu Jul 21, 2022 11:21 am
True! You can stil get 4.2 though. At least main VCU can be assembled.
I am in process of building another VCU from esp32 chip. Esp32 can be get cheap and i used a lot of its pins. Main goal was to rebuild Leaf or Chademo VCU with esp32 replacing SAM.
I am using the same aliexpress 24pin shell you used for your VCU.
Drawback is it only has one CAN port. If i stretch its design a bit i could make a second SPI CAN. But i decided to setup as charger, BMS and inverter control first. Then i can make more complex iterations.
I just need to transfer code functions from DUE to esp32...
Posted: Thu Jul 21, 2022 11:48 am
by aot93
Ha! I literally just sat down and stated playing with the esp32 as well!
My project for this one is for a chademo controller.
The single can is a pain, I might try to the port the dash controller board to esp as it only needs 1 bus, and the build in WiFi Bluetooth could be interesting.
Posted: Thu Jul 21, 2022 12:45 pm
aot93 wrote: ↑Thu Jul 21, 2022 11:48 am
I already designed it. Also i just got the word pcbs have arrived. So whats left is to tweak the code. If you want i can publish my design and you can work on the code so as not to repeat the work. Code is my weak point...
Posted: Thu Jul 21, 2022 1:13 pm
by aot93
Happy to take a look, although I'm away working for the next or month so have limited test kit with me.
Posted: Tue Jul 26, 2022 6:08 pm
by GeneralScanner
Hi arber333
Sorry for the delay new to the forum thing...
Managed to find a teensy 4.1 just need a board to put it on.
Whichever boards you have from this project I will take one of each...
I'm just outside of Cambridge UK
Thanks G
Posted: Sat Jul 30, 2022 5:30 pm
by nlc
Ok now I am able to drive the inverter/motor :
- I start the car with all CAN IDs from car to inverter filtered but 0x285
- When high voltage is present on inverter, I emulate 0x288 frame from inverter to car with my computer to prevent the car to detect error and stop high-voltage on inverter, and I filter all frame from inverter to car
- I filter the 0x285 frame from car to inverter, now the inverter is completely isolated from CAN point of view.
- I shut down the inverter 12V (by disconnecting the harness connector)
- I powerup the inverter (by connecting the harness connector)
- I send homemade 0x285 frame to the inverter and it works
Posted: Sat Jul 30, 2022 6:25 pm
by EV_Builder
The last three steps how often can you repeat that?
Posted: Sat Jul 30, 2022 7:31 pm
by nlc
Sorry I made a mistake my original message was here :
https://openinverter.org/forum/viewtopi ... 305#p43305
Posted: Sat Jul 30, 2022 7:34 pm
by nlc
EV_Builder wrote: ↑Sat Jul 30, 2022 6:25 pm
I tried 2 times
Posted: Wed Aug 17, 2022 9:19 am
by m1n1s
Hi Guys,
Starting my build any one have any pcb boards i can buy?
Posted: Wed Aug 17, 2022 1:15 pm
by aot93
Good news is the teensy 4.1 seems to be back in general stock.
Bad news is the 3.x ones are still a way off by the looks of things, which makes the BMS side of things tricky.
If there is interest I can order do an order for some vcu boards from JLCpcb will take a few weeks on cheap shipping
Posted: Sat Aug 20, 2022 8:08 am
by Drivelafrance
Hi all,
I've sat around for so long (aot93 very kindly provided me with some boards) that I've hit issues getting hold of a 3.2 for the BMS.
Is anybody working on a BMS using a 4.1 or perhaps ESP32 which I could try to muck in with?
