No longer Wanted(UK): 24v Battery 150-200Ah
Posted: Sat Nov 27, 2021 8:13 pm
On the lookout for a 24v battery system to finish off the sawdust spreader project. I've been looking on Aliexpress for Lifepo4 cells and in lead acid like form factors with built in BMS. It's a pretty simple project so plug and play would be pretty nice. It's also spending it's life on a farm so simplicity and durability are my main focuses.
Thought I would see if anyone has anything lying around in the UK rather than spend the rest of the winter waiting for delivery from China.
Open to chemistries, will be charged below 0.2c, got quite a lot of space available for the capacity requirement, weight isn't an issue either.
Specific requirements are:
125A(150A in an ideal world to be safe) continuous discharge
150Ah-200Ah capacity
24v nominal
24v nominal
