Hi. Starting the trial and error marathon
Audi A2 1.6fsi as a recipient. 550Eur.
OpenInverter VCU 180Eur.
Prius gen2 gearbox 100Eur.
Prius gen2 inverter 65Eur.
Chev Volt Gen2 80 cells 900Eur.
Prius shafts 50Eur.
Oil for gearbox 15Eur.
Total 1860Eur.
Gearbox was tested on the bench.
Batteries, will be sourced later. Anything from scrap.
Goal to test myself and do it very cheap.
Re: Audi A2 with Prius Gen2
Posted: Wed Nov 10, 2021 10:21 am
by RetroZero
Looks very familiar .
Gen 2 transaxle is great, but bulky and heavy for small fwd. You will need 2 adapter boards if the aim is Mg1 and Mg2. If you want to go real cheap, yaris inverter and Damiens dual motor board, but you then need to modify motor cabling to inverter. Choices, choices.
I read you wrote "Prius transmission would be beneficial for registering, because no EMC testing is required. But I think it is too tall to fit,"
I measured it and I didn't find any issues to fit it. I plan to center Prius transmission, weld Prius driveshafts to A2 driveshafts.
Was planning to start making mounting brackets this weekend, but my workshop is in now restricted area because of immigrants from Belarus (declared state of emergency)
johu wrote: ↑Wed Nov 10, 2021 4:50 pm
Cool, looks like we'll be doing the exact same thing: viewtopic.php?f=11&t=650
Posted: Wed Nov 10, 2021 6:25 pm
by geduxaz
I would like to use only MG2, remove MG1 from transaxle to reduce weight.
RetroZero wrote: ↑Wed Nov 10, 2021 10:21 am
Posted: Wed Nov 10, 2021 7:29 pm
by RetroZero
Been thinking the same. Even better, make a blank off plate and remove Mg1 completely. More space for batteries etc. All that said, dual motor is a good option too, for larger vehicles. I'm scratching my head for rwd that could welcome a transaxle. Combi comes to mind
Posted: Sat Jan 15, 2022 6:55 pm
by geduxaz
After long time made small steps forward.
Decided to put VCU into original ECU housing and use audi ecu connectors.
Car moves. Now need to fine tune SyncOffset and put Volt Gen2 battery pack.
Posted: Fri Feb 04, 2022 11:07 am
by geduxaz
Audi throttle pinout:
First sensor 1 (24 on ecu) is +5V, 5 (19 on ecu) is Gnd, 6 (33 on ecu) is signal;
Second sensor 2 (43) is +5V, 3 (18 on ecu) is Gnd, 4 (15 on ecu) is signal;
Posted: Fri Feb 04, 2022 11:08 am
by geduxaz
Shaft were made from Audi external and Prius internal shafts. Welded together with additional pipe pressed on them together.
Posted: Fri Feb 04, 2022 11:17 am
by geduxaz
Posted: Fri Feb 04, 2022 11:34 am
Excellent. Are you using both mg1 and mg2?
Posted: Fri Feb 04, 2022 12:07 pm
by geduxaz
Jack Bauer wrote: ↑Fri Feb 04, 2022 11:34 am
Only MG2. If all goes well I plan to remove MG1 and reduce weight.
Posted: Fri Feb 04, 2022 12:23 pm
by geduxaz
Some info to remember
Posted: Fri Feb 04, 2022 3:29 pm
by RetroZero
Congratulations . How did you resolve the forward reverse problem?
Posted: Fri Feb 04, 2022 5:01 pm
by geduxaz
RetroZero wrote: ↑Fri Feb 04, 2022 3:29 pm
This was test on backwards direction could easily spin wheels on some snow till it melted snow and heated tyres . Lots of power. But i am not happy. Need to make forward go forward.
Also in video rear had like 300+ Kg of lead batteries. Now it is lithium- more light.
Posted: Sat Feb 05, 2022 7:56 am
by EV_Builder
What do you mean the car moves forward in the video?
Posted: Sat Feb 05, 2022 8:51 am
by geduxaz
It is selected as rewerse in vcu but motor spins forward
Posted: Sat Feb 05, 2022 9:02 am
So it's just the label that bug you? Because otherwise there is no difference between fwd and rev
Posted: Sat Feb 05, 2022 10:01 am
by geduxaz
Really? There were some comments that this should not be used as this.
Is all the regens etc also working the same on reverse?
Posted: Sat Feb 05, 2022 10:27 am
by EV_Builder
There is a setting johu knows so you can swap the firing of the phases I think that will do the trick. I agree that fwd in software should be forward of the car.
Posted: Sat Feb 05, 2022 10:43 am
by geduxaz
Guys, there is too much miscommunication. If Johu (master of this system) now wrote that moving forward on reverse is OK, then i will continue this way.
If there was any setting that would swap phases for direction, i believe Johu would already wrote it. It is not the same as pinsawp for correct current measurement.
What i will try to do- i will try to play with resolver to get angle rising not falling.
Posted: Sat Feb 05, 2022 3:57 pm
geduxaz wrote: ↑Sat Feb 05, 2022 10:01 am
To my knowledge all tesla SDU people have to do that, same story there. Regen works the same in reverse.
Posted: Sat Feb 05, 2022 5:15 pm
by geduxaz
Roger. Thats it. I will not try anymore to swap direction.
Tomorrow will make test rides and will continue on canbus messages to audi to make everything work.
SyncOfs is something 10000-11000. Now set at 10300.
Second offset is around 43000 but wheels have almost no power. All good when wheels in air, but no movement on the ground.
So i could say there is only one correct offset..
Posted: Sat Feb 05, 2022 6:11 pm
by Gregski
luv it, followink
Posted: Sun Feb 06, 2022 12:10 pm
by geduxaz
some test on the snow. Summer tires with no traction.
Also could make burnouts on the concrete.
Removed fuel tank, exhaust, fuel lines. In general nothing is left from the petrol system.
My wife gonna kill me. Its too cold and i think i am going to get ill
