Gen2 tesla charger with commercial firmware [SOLVED]
Posted: Thu Nov 04, 2021 11:33 pm
by qmedia2651
My gen2 charger have to press the reset button so the program can start after that it works fine.
Has any one had this problem?
Please advise. Thanks
Re: Gen2 tesla charger with commercial firmware
Posted: Fri Nov 05, 2021 11:48 am
by jon volk
Are you programming over wifi or SWD? I only need to reset/power cycle after an SWD flash. I wouldn't classify that as a problem unless I'm not understanding your situation.
Posted: Sat Nov 06, 2021 12:11 am
by qmedia2651
SWD programming this is happening at all times.
If I turn gen2 charger off and get it back on power led ok on but no blinking LED. Must reset button so that the led can start blinking wifi ok and updates well.
Posted: Sat Nov 06, 2021 12:20 am
by qmedia2651
Hi JON VOLK I'm from Orlando Florida working on a 1991 300CE Mercedes conversion SDU logic board completed except waiting for the STM32F103RBT6 from China cannot get them from USA. I do my own PCB. I'M USING wimos wifi with a shield I designed.
Posted: Sat Nov 06, 2021 12:29 am
by qmedia2651
Should led start blinking when powered on?
My LDU board led blinks constantly when powered on.
Posted: Sat Nov 06, 2021 6:36 am
by Boxster EV
qmedia2651 wrote: ↑Sat Nov 06, 2021 12:29 am
Yes. During charge and otherwise.
Posted: Sat Nov 06, 2021 2:41 pm
by jon volk
If you’re having to press reset on every power cycle that doesn’t sound right, but not something I’ve seen anyone ever have a problem with.
Did you get your own pcb made for the charger as well?
Posted: Sat Nov 06, 2021 3:08 pm
by qmedia2651
Yes indeed I did
Posted: Sat Nov 06, 2021 3:09 pm
by qmedia2651
No problem with the others
Posted: Sat Nov 06, 2021 3:12 pm
by qmedia2651
Going to do a reflow to see if it solves the problem.
Posted: Sat Nov 06, 2021 3:31 pm
by qmedia2651
I think I know what's going on I didn't install the bootloader. Do you have to install a bootloader on this too. Is this possible?
Posted: Sat Nov 06, 2021 3:33 pm
by qmedia2651
Is there an update for the commercial firmware?
The instruction didn't say nothing about any bootloader.
Posted: Sat Nov 06, 2021 5:00 pm
by jon volk
It absolutely says plenty about a boot loader file.
https://openinverter.org/wiki/GEN2
Posted: Sat Nov 06, 2021 5:51 pm
by qmedia2651
yes my bad will it start without a loader ?
Posted: Sat Nov 06, 2021 8:41 pm
by jon volk
No, the loader should be telling where to jump to on application startup. The reset button causes a jump to a reset vector, which is likely why it runs if you press the button.
Posted: Sun Nov 07, 2021 3:03 pm
by qmedia2651
What if I jump boot0=1, and boot1=1 on the board .
Posted: Sun Nov 07, 2021 3:25 pm
by jon volk
Just install the boot loader…..
Posted: Mon Nov 08, 2021 1:01 am
by qmedia2651
Thanks Jon will do
Posted: Mon Nov 08, 2021 4:14 pm
by qmedia2651
Got it working now blinking when powered up. the problem was not the bootloader it had the bootloader installed. I just jumped BOOT0 to ground on my board V5 had jumper pins for Boot0 and Boot1.
When I hooked up the ST-Link it started Blinking but when It was hook up to the 12V input at the Charger it didn't blink so I set the Boot0 to Ground and it started to blink.
I then powered off and installed my Wimos D1 Mini WIFI set Parameters and charger started charging.
Thanks to all for your input
Posted: Fri Nov 19, 2021 1:43 am
by qmedia2651
Does anybody know how to get the gauges on the WiFi.
Can't get the gauges to show up
Posted: Fri Nov 19, 2021 3:35 am
by m.art.y
qmedia2651 wrote: ↑Fri Nov 19, 2021 1:43 am
Tick little boxes next to the parameters which you want to see in gauges and then press show gauges. If no parameters are selected no gauges will show as it does not know what you want to see and it does not show all parameters in gauges by default.
Posted: Fri Nov 19, 2021 12:12 pm
by qmedia2651
Thanks a lot Marty I just recieved my Stm32f103rbt6 for my SDU and just finished programming it.
I installed V5.12R Hex firmware
Posted: Fri Nov 19, 2021 6:17 pm
by qmedia2651
Any one know what file system is used to upload videos.
Trying to upload my project videos.
Posted: Fri Nov 19, 2021 6:19 pm
by m.art.y
Upload them somewhere and give us a link
Posted: Fri Nov 19, 2021 6:32 pm
by qmedia2651
Okay
thanks Marty
