J1772 Type 2 and Brusa NLG513
Posted: Sun Oct 03, 2021 2:10 pm
Hi Forum. Just looking for info on whether the Brusa NLG513 can be used with a J1772 Type 2 charging cable ? If so any pointers please. Thanks. Peter
openinverter Community
https://openinverter.org:443/forum/
Here i convinced EVSE to open and supply AC at 16A. I wired one 2K7 resistor and additional switch and 1K3 resistor to PE that brings total CP resistance to some 880R. I did that inside the handle.Zapatero wrote: ↑Sun Oct 03, 2021 4:31 pm As it is can controlled i would say you need some extra hardware that converts the pwm signal of the J1772 to a can message that tells the charger the max. charge limit allowed at the moment. It also has to communicate with the bms for SoC and highest and lowest cell information etc... Also it has to have the simple hardware around the 2.7 kΩ resistor.
So i doubt the charger itself is capable of J1772 but with some addon it can be easily be can controlled to work with J1772.
if you have an aftermarket BMS as Orion BMS 2 for example its fairly easy to set up!
This 880R 'trick' won't work anymore with a lot of public EVSE's here in The Netherlands (Allego in specific) becaue these want you to follow the right steps/status in the right order as the protocol specifies to get them working:arber333 wrote: ↑Sun Oct 03, 2021 5:24 pm
Charger then started CAN telegram from PP present signal which pulled some input pin on my CAN uC to GND.
https://mazdamx3ev.wordpress.com/2018/0 ... nica-evse/
Yes, this is the reason behind the button (or switch) and 2 resistors. This means when Plug will be inserted EVSE will go from status A to status B (button pressed) and when i release this button EVSE will see status C. This will also work on Tesla EVSE chargers, but you need to hold the button for 20s or soprensel wrote: ↑Sun Oct 03, 2021 5:51 pmThis 880R 'trick' won't work anymore with a lot of public EVSE's here in The Netherlands (Allego in specific) becaue these want you to follow the right steps/status in the right order as the protocol specifies to get them working:arber333 wrote: ↑Sun Oct 03, 2021 5:24 pm
status A: standby (open)
status B; vehicle detected (2K7)
status C: charging request (880R)
Jumping from status A to status C triggers a fault situation and the EVSE in question 'kicks' you off, it even unlocks the cable (which it SHOULDNT)
Do i get this right that the EVSE can activate the charger? Without communicating via can with the bms, how does the charger know what the BMS suggests as charge limit concerning battery temperature too high or too low, single cell voltages too high or too low and so on?prensel wrote: ↑Sun Oct 03, 2021 5:43 pm Yes the NLG5 does support it,
There is a CP (ControlPilot) input connection available to be direclty connected to the EVSE.
You have to trigger the signal though by means of a CANbus message.
I never got it working properly in 'stand-alone' mode (without CANbus) but with it works fine.
No, the charger always activates/controls (hence the name ControlPilot) the EVSE.Zapatero wrote: ↑Sun Oct 03, 2021 8:17 pm
