Page 1 of 1
Regen on braking
Posted: Sat Sep 11, 2021 6:13 pm
by Bigpie
Struggling to get regen working when I brake, potnom doesn't seem to drop below 0 and I don't feel any change. Ideally, I want it only when braking, so that I can lightly touch the pedal for regen down hills and just lift off to coast.
din_brake goes high with the brake pedal. I've got:
"brknompedal": -30,
"regenramp": 10,
"brknom": 0,
"brkmax": -10,
"brkcruise": -30,
"brkrampstr": 15,
"brkout": -50,
Re: Regen on braking
Posted: Sun Sep 12, 2021 9:47 am
by Peter
Hi Bigpie. I guess you mean potnom2 ? I will check my settings and reply as I had initial difficulty. Peter
Posted: Mon Sep 13, 2021 7:04 pm
by Peter
Hi Bigpie. My settings....
throtmin -100
idcmin -100
pot2min 0
pot2max 4095
potmode SingleRegen
brknompedal -60
regenramp 50
brknom 0
brkmax 0
brkrampstr 100
brkout -100
Posted: Mon Sep 13, 2021 7:28 pm
by Bigpie
Thanks, I'm using a can throttle, so maybe that's my issue. I'll have to faff with it some more.
Posted: Mon Sep 13, 2021 8:44 pm
by Peter
Ah, good luck and hope hope you crack the issue ASAP.
Posted: Mon Sep 13, 2021 8:46 pm
by Peter
Just thinking.. Are you using brake ON signal and a manual pot for regen ?
Posted: Thu Sep 23, 2021 8:30 am
by Bigpie
Got this sorted now, was missing a value for pot2, now using the brake pressure value from canbus but I need to tweak around now it's working. The brake pressure value range is quite low, 120 - 255 so getting poor results at slow speeds coming to a stop.
Posted: Thu Sep 23, 2021 2:48 pm
by johu
Bigpie wrote: ↑Thu Sep 23, 2021 8:30 am
Yes same here (obviously because VAG car). I think I just use the range up till 180 or so because after that you're quite hard on the brakes already. If you configure pot2max below 255 anything above pot2max will result in the maximum programmed regen
Posted: Thu Sep 23, 2021 3:46 pm
by Bigpie
It's more the coming to stop, when moving slowly, the regen was hammering on and off quickly. I think I need to disable regen below a certain speed/
