Page 1 of 1
nissan note e-power
Posted: Wed Aug 11, 2021 6:34 pm
by earthman
hi, does anyone know how the nissan note e-power inverter works? there is an idea to use its 2 generator motors to build an electric car
Re: nissan note e-power
Posted: Thu Feb 03, 2022 11:34 am
by jalovick
I've just ordered the motor set and am looking for an inverter to play with myself. The main motor is a well documented EM57, and the 2021 and newer models will have an EM47 that is smaller and more powerful. There are 2WD and 4WD configurations.
I've gathered some part numbers:
- Inverter (likely FWD version)- 291A0-5WK0A, and I've seen a 291A0-6XK0A (the last digits seem to relate to the model or variant of the vehicle)
- Generator (FWD) - 290C0-5WK0A
- Generator (AWD) - 290D0-5WK0A
- EM57 - 290A0-5WK0A
5WK0A seems to relate to the HE12 Note e-Power and 6XK0A seems to relate to the HE13 Note e-Power.
The newer Nismo S version (2016 or 2018 onward) has a 100 kW capable inverter.
I'm not sure if anyone on the forum has played with the setup, but it may be fairly similar to the Nissan Leaf.
Jamie
Posted: Fri Feb 25, 2022 3:18 pm
by Scrappyjoe
Subscribed - I want to transplant an e-power power plant into my vanagon in 2025, so here to learn.
Posted: Sun Feb 27, 2022 8:19 pm
by Scrappyjoe
Jamie, do you have any good resources on how the system functions? I’ve got a lot of questions about how it all works together but all I can find are Nissan promo materials and Facebook groups.
I’m trying to find out things like if the ICE & generator unit can be manually controlled via canbus, what voltage the little battery pack is, how the handoff from battery to generator power works etc.
Posted: Fri Mar 10, 2023 11:11 am
by mabubakar44mb
First of all mg2 and mg1 are separate mechanically in this nissan note e power unit. The ICE is only run mg1 and its charge the HV Battery. There to power modules 1 is for control the mg2 and 2nd is to start the ICE and after starting its use as charging the HV battery. You can see the videos about its mechanism. I also want to use the complete setup to make an EV car where I can use mg1 for charging the battery system when ever i am going on long tour because at this time we don't have charging stations in my country like fuel stations. If any one have an idea how to get start ICE with its own ECU and wiring.
Posted: Fri Mar 24, 2023 8:19 pm
by Scrappyjoe
Well I don’t know where you live but if I were to try this I would look for salvage Notes in Japan and ship across the entire car. Then I’d strip everything off, incrementally deleting error codes in the ECU until I had isolated the ICE, two motors, battery and pedal. Then I’d install it in another car.
Looks to me from googling that a damaged/written off ePower goes for anywhere between $2000 and 7000 depending on the amount of damage.
Posted: Thu May 02, 2024 10:37 am
by theendlessriver
earthman wrote: Wed Aug 11, 2021 6:34 pm ноут.jpghi, does anyone know how the nissan note e-power inverter works? there is an idea to use its 2 generator motors to build an electric carноут2.jpg
Great idea. I been looking to do the same. I know the leaf and prius has been unlocked for ev conversions but i haven't seen anyone playing around with nissan e-power setup. Any update on it yet?
Posted: Thu May 02, 2024 11:54 am
by Romale
I use them perfectly. but not the factory version. I'm putting up the oi v3 boards
Posted: Wed Jul 10, 2024 3:00 pm
by Driftman
Hello!
I have a Nissan Note e-Power, and there is a version of Nismo S, as far as I understand, both versions have the same engine EM57, but Nismo S produces 100 kW. Do I understand correctly that the main difference is in the inverter? Can I simply replace the inverter and get 100 kW? Maybe someone who already understands well can tell me.
Thanks everyone!
