Nissan Leaf PDM relays
Posted: Thu Jul 15, 2021 8:32 am
I will likely swap my charge port relays for the Leaf PDM ones, part number Omron G9EA-1-NP
One relay by itself would draw 7 W and I think pissing away 14W for the relays is a bit much. I do have my RC economizer in place and was just going to test it on my bench, when I discovered the magic:
On top of the relays sits a PCB and I never payed much attention to it. Turns out when you feed 12V to pin 1 and GND to pin 2 it actually sequences AND economizes the relays for a total draw of 3W !
So definitely keep that PCB when raiding the PDM.
