How to charge HV batteries off car?
Dan--T
Post by Dan--T »
Hi, this is probably a newby question,. But what is the simplest way to charge HV automotive batteries up when they're not connected to the car?
I want to use my Lexus hybrid battery pack as a test battery to get things moving but I need to charge it up first,. And I guess I'll need to do the same once I have purchased my proper battery.
What is the recommended method?
(Please bear in mind I am not an electrical engineer so can't knock something up using a Prius inverter and some copper wire)
Dan
ZooKeeper
Has thanked: 8 times
Re: How to charge HV batteries off car?
Post by ZooKeeper »
For a hybrid pack, especially Toyota/Lexus ones, my suggestion would be one module at a time while secured in their case.
Time for ICE Melt
Isaac96
Post by Isaac96 »
As ZooKeeper said. You can either use a proper charger or just a simple lab power supply - those have both current and voltage control so they charge batteries safely, also they're generally useful for EV conversion work.
ZooKeeper
Post by ZooKeeper »
Isaac96 wrote: Wed Jul 07, 2021 1:15 am As ZooKeeper said. You can either use a proper charger or just a simple lab power supply - those have both current and voltage control so they charge batteries safely, also they're generally useful for EV conversion work.
Yea, I know... so useful I am amassing a collection of them :ugeek:
Time for ICE Melt
Been thanked: 411 times
Dan--T wrote: Tue Jul 06, 2021 11:21 pm Hi, this is probably a newby question,. But what is the simplest way to charge HV automotive batteries up when they're not connected to the car?
Dan
See here is a hard core method, but it works for every kind of automotive battery you can imagine :).
https://leafdriveblog.wordpress.com/202 ... r-charger/
You can get a smaller version autotransformer for single phase connection and it will work up to 300Vdc or so.
If you dont need to have a fast charging then i recommend you buy a simple PSU for voltage you need to get battery to.
rstevens81
Has thanked: 29 times
Been thanked: 114 times
Post by rstevens81 »
If they are in simple modules you can charge each module by themselves with a cheap lion charger from China land (if you open them up you can change the charge point voltage)
I did this 12 at a time to 3.75volts (45v) to put my modules into a storage state. I also monitored the BMS to be extra safe.
Dan--T
Post by Dan--T »
Ok, I ideally didn't want to have to split open the battery pack but if that's the best/ only feasible way to do it I can.
So I think each lexus cell is 7.2v,. So I just need to buy a power supply capable of over 7.2v and do them all one at a time?
ZooKeeper
Post by ZooKeeper »
Dan--T wrote: Thu Jul 08, 2021 9:42 pm So I think each lexus cell is 7.2v,. So I just need to buy a power supply capable of over 7.2v and do them all one at a time?
The modules are wired in series, the only way to do them all at once @ 7.2v is to turn every other one around so all the (-) & (+) terminals are on the same side.
Time for ICE Melt
RetroZero
Has thanked: 643 times
Been thanked: 64 times
Post by RetroZero »
What about the prius gen 2 Inverter as charger? There's a thread and quite some work done. Needs some fine tuning and testing from what I understand. I hope to get into that part pretty soon as I too have a hybrid pack that needs recharging. If I understand correctly, if there is no bms, current and voltage has to be real low as the weakest modules are going to take most of the first phase of charging.
marcexec
Has thanked: 1039 times
Been thanked: 111 times
Post by marcexec »
If you have to buy, I can recommend Meanwell LED power supplies. They come in various voltages and power levels and are current and voltage adjustable. I run a pair of waterproof HLGs to charge my bike overnight without issues (after switching to waterproof...).
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Dxtawise
Has thanked: 4 times
Post by Dxtawise »
I think you could use a bunch of LED power supplies connected in series for this job.
r1ckyb0nd
Has thanked: 11 times
Been thanked: 9 times
Post by r1ckyb0nd »
Dan-t,
Where you successful in using the battery pack on the bench?
I am looking to do the same.
r1ckyb0nd wrote: Mon Sep 01, 2025 12:30 am Dan-t,
I have one Chevy Volt pack on the floor for my HV test source. It works great for years now. I also use one Mitsu Outlander OBC/DCDC. However i need to be careful here as i dont have liquid cooling connected. I only have water in charger and hose looped between ports to have some thermal mass.
I charge slow at some 3A => 1kW.
3PH autotransformer setup i use as quick charger in case if all my chargers would somehow fail or i would really need to charge quickly....
r1ckyb0nd
Post by r1ckyb0nd »
Can you share how you connect to the hv battery and any documentation on how you (if you do) control the BMS?
r1ckyb0nd wrote: Mon Sep 01, 2025 10:04 am Can you share how you connect to the hv battery and any documentation on how you (if you do) control the BMS?
Its rather complicated.
I used simpBMS connected to Ampera OEM BMS. It was not much, only CAN lines and power supply. But in the end i removed simpBMS in favour of Hanzor BMS because i could read 12S packs via Bluetooth and for SimpBMS i would have to have serial connected.
Generaly i made simple connections from cell tabs to screw terminals. From there i can use whatever connectors and BMS i like.
Lately i experimented a lot with ZEVA BMS...
viewtopic.php?p=78097#p78097
Last week i made changes in my workshop and now i will use Volt gen2 battery. Probably i will use ZEVA BMS. If you like i can post my assembly here.
r1ckyb0nd
Post by r1ckyb0nd »
Yes please
