Page 1 of 1
Inverter P/N Compatible with V1c Gen 3 board? (G9200-47230)
Posted: Wed Jun 30, 2021 1:22 pm
by invokeperformance
Hello does anyone know if this 2014 Prius inverter P/N (G9200-47230) compatible with the V1c board it not listed on the WIKI under Toyota part numbers. I believe it is just want to confirm before buying. thanks
Re: Inverter P/N Compatible with V1c Gen 3 board? (G9200-47230)
Posted: Wed Jun 30, 2021 2:31 pm
by ZooKeeper
If I recall correctly, the important numbers are on the control board inside.
Posted: Wed Jun 30, 2021 3:19 pm
by LeonB
I have the same inverter and the v1d small board fits in nicely. Thus, I think that the v1c board is too big.
Posted: Wed Jun 30, 2021 6:01 pm
LeonB wrote: Wed Jun 30, 2021 3:19 pm I have the same inverter and the v1d small board fits in nicely. Thus, I think that the v1c board is too big.
thanks that's good information what year car is your inverter from?
Posted: Wed Jun 30, 2021 6:52 pm
by LeonB
invokeperformance wrote: Wed Jun 30, 2021 6:01 pm
2015
Posted: Wed Jun 30, 2021 7:40 pm
by Bigpie
Please update the wiki with details
Posted: Wed Jun 30, 2021 8:41 pm
by angusmf
Bigpie wrote: Wed Jun 30, 2021 7:40 pm Please update the wiki with details
I've seen this info in other threads as well. 2010-2011 use the "large" boards, everything Gen 3 after that uses the "small" boards originally for the Auris/Yaris. V1D (I believe) is specifically for dual motor where V1C is for single, and they're both available in small and large designs. Single motor will be a bit cheaper.
FWIW, the small board inverters seems a hair cheaper to buy used.
