Using float on STM32F1
Posted: Wed Jun 30, 2021 8:50 am
After playing with the F4 a bit I thought it would be pretty neat to be able to use floats on the F1. Yes it will be soft-float but that should be ok for the slower 10 & 100ms tasks. I would like to restrict the fixed-point math to the 8.8 kHz control ISR only.
Problem so far has been that using any sort of float operation would result in a hard fault. That is because gcc by default uses the "wrong" libgcc.a.
I have forced it to use one with floating point implemented by changing LDFLAGS from
to
-Llibopencm3/lib -L/usr/lib/gcc/arm-none-eabi/11.1.0/thumb/v7+fp/softfp -T$(LDSCRIPT) -nostartfiles -Wl,--gc-sections,-Map,linker.map
There is probably a better way to do this, i.e. not having an absolute path in there.
UPDATE: there is. Just specify -march=armv7
I think this is particularly interesting for the ZombieVerter project as that has no fast loops at all.
-Llibopencm3/lib -T$(LDSCRIPT) -nostartfiles -Wl,--gc-sections,-Map,linker.map-Llibopencm3/lib -L/usr/lib/gcc/arm-none-eabi/11.1.0/thumb/v7+fp/softfp -T$(LDSCRIPT) -nostartfiles -Wl,--gc-sections,-Map,linker.map
-Llibopencm3/lib -march=armv7 -T$(LDSCRIPT) -nostartfiles -Wl,--gc-sections,-Map,linker.mapUPDATE: there is. Just specify -march=armv7
