Charging from Gen2 Prius?
alehandro
Post by alehandro »
Greetings to the guests of the forum. I really want to figure out if it makes sense to use the Gen2 inverter to charge a high-voltage battery. The answer to my question, I would like to hear from people who successfully use the Gen2 prius inverter as a charger for a high-voltage battery.Thanks for any help.
LRBen
Has thanked: 43 times
Been thanked: 106 times
Re: Charging from Gen2 Prius?
Post by LRBen »
There has been a bit of discussion on the topic here:
viewtopic.php?t=1070
So far it's all been bench tests.
ZooKeeper
Post by ZooKeeper »
It works, but the order of operation is critical. All the important information is in the topic linked by LRBen above.
