Page 1 of 1
RX450h inverter
Posted: Wed Jun 23, 2021 6:22 pm
by krivansky.tomas
Have someone experience with RX450h inverter? Some schemes, documentation, links? Some suggestions with which from control boards it can be controlled?
Thanx
Re: RX450h inverter
Posted: Tue Jul 06, 2021 7:44 pm
by krivansky.tomas
Hi guys. Im sending you a few pictures from disassembly of my RX450H inverter
Re: RX450h inverter
Posted: Wed Jul 07, 2021 9:43 pm
by krivansky.tomas
I found what I needed
viewtopic.php?f=14&t=757&p=10870&hilit=rx450#p10870
now Im gonna buy GS450h VCU
Re: RX450h inverter
Posted: Wed Jul 14, 2021 11:53 pm
by Lwerewolf
Have I missed some recent developments?
Pretty sure that you won't be able to control this inverter with the gs450h VCU using the, ehh... "stock" code.
Re: RX450h inverter
Posted: Thu Jul 15, 2021 5:36 pm
by krivansky.tomas
Lwerewolf wrote: Wed Jul 14, 2021 11:53 pm Have I missed some recent developments?
Hi. Actually Im not sure that I will be able to control rx450h inverter with gs450h VCU. I have to try it! Control signals/pins are looking similar. So I suppouse there is a chance.
Now I dont know what version of gs450h VCU shoult I order. On github is visible there are existing 3 versions.
https://github.com/damienmaguire/Lexus- ... Controller
V1,V2,V3
Damien only offers V1 on his EVshop
https://www.evbmw.com/index.php/evbmw-w ... gs450h-vcu
Can someone advise? what to order?
Thanx
Re: RX450h inverter
Posted: Fri Jul 16, 2021 6:01 am
by celeron55
Electrically the gs450h vcu should be fine, but the data the rx inverter wants are different. You'll have to capture the rx450h data from a running vehicle, reverse engineer it and modify the code to produce that data.
