For anyone looking to use this, the output connector can be found on:
General Motors p/n 84024993
Tesla p/n 1100169-00-D, or 110900410-G (?)
Check the key of the connector, whatever part you buy. Only Key A will work!!!
I’m told theres also a volvo harness with this connector, but I don’t know the part number.
Re: Chevy Volt Gen 2 charger 24281923
Posted: Thu Nov 17, 2022 7:17 pm
by vwbrady
any key will work with a little trimming
Posted: Fri Nov 18, 2022 2:39 am
by 86elcamino
arber333 wrote: ↑Fri Aug 19, 2022 6:02 am
DcDc can be connected to HV directly. If you show it PWM it starts with 14V. But if you remove PWM it will revert to 13.6V as a failsafe.
Charger will require 100Hz PWM signal to run and BMS to stop it when pack is full.
I bet you could get zombieverter to output 2x PWM signals for you...
Thanks for the input. Do you know how to get the Zombieverter to output the PWM signals? Do you know what is required for the Volt Gen 2 BMS to operate? Sorry if these are silly questions, my electronics knowledge is limited, I appreciate you sharing yours.
I am not sure…
Mine has less markings on the AC connector than it did on the DC one, just says “DELPHI”
But I have not spent much time looking for it yet.
Posted: Wed Sep 13, 2023 6:08 am
by Gregski
this Chevy Volt video popped up on my YouTubes and I thought you may want to see how the charger works in an actual Chevy Volt and how it wants to charge at 8 amps and you need to force it to 12 amps
Posted: Wed Sep 13, 2023 9:21 am
Gregski wrote: ↑Wed Sep 13, 2023 6:08 am
Well i tried to force pwm to my gen2 charger (when i had one at home) to charge actual gen2 battery (also here). I could get up to 9A at 90% duty signal and after 92% charger wouold trip out and stopped charging. But curiously enough 9A would start as low as 78% duty. Again i didnt connect any coolant to it so any excercise was brief.
Maybe there is something to the PWM signal i didnt figure out. Feel free to play with it .
Posted: Wed Sep 13, 2023 8:44 pm
by TonyV
The most I ever saw was 12amps but, the battery was very low on charge.
But when the battery was almost fully charged the amps output dropped to around 8.9 amps.
Both readings were from the DC side of the charger.
Posted: Tue Nov 07, 2023 1:19 am
by Persanity
Hey guys does this information help? This seems like it explains the correct way to communicate with a EVSE/power source to function like it was in a stock vehicle.
