Leaf Adapter Board - Noob Questions
Posted: Tue Jun 01, 2021 12:04 pm
Just working though the Nissan Adapter board and general OpenInv documentation.
Any help on the following very much appreciated.
A)Is there a source for spare pins for the inverters Nissan OEM connector. (49way) Loom Side.
B)Throttle2: Is this a software selectable input for dual track throttles or single track throttle & variable regen pedal?
C)5V (Pin 26) is this supplied by the OpenInv MainBoard or from the Leaf Inverter OEM board.
D)The throttle input (Pin29), is this 0-3.3V only input. Should I rescale a 0-5V throttle pot signal.
Thanks, J.
Thanks, J.
