TSDU - Strange intermittent OVERCURRENT fault
Posted: Wed May 05, 2021 1:21 pm
Damien board V4 running on a 55V 60A PSU for HV. Tried some 4.x firmwares and also just tried 5.0 with no difference
I seem to have an intermittent fault with overcurrent being thrown as soon as you try to enter Run mode. Sometimes it's fine and drive unit works fine, other times it instantly kicks out when going from precharge > run.
I've tried inverting the sign of ocurlim (this one is especially weird as I feel i've had it working with both a negative and positive sign without changing firmware level)
I think I'll have to split the inverter, thinking it must be a dry contact - I can't see any way to explain why sometimes the unit sometimes works fine. Is the only way to trigger the OVERCURRENT purely from the hardware overcurrent circuit? This is a current limited supply, so in theory there is no way I can be hitting 1200A.
EDIT: I've switched over to using a bench supply for the HV - anything up to 27V seems to be fine and the unit reliably gets into run mode and works fine. Not seeing any current spikes at all going from precharge > run. anything above 30V seems to intermittently hit ocurlim (but again there is no current spike) - It has to be a board issue I guess, if it spins OK on less presumably the inverter and power stage is fine
