CAN BUS Throttle issue
Posted: Sat May 01, 2021 5:10 pm
I'm having an erratic throttle at the inverter, the min throttle value is 815.
My setup is a rev 3 main board running stm32-car and a Prius gen 3 inverter board from EVBMW
The signal is steady on the rev 3 board and the CAN BUS logs are outputting a steady 815/816 but the inverter keeps dropping.
Can H to L resistance is 45 ohms, so no the ideal 60, not sure if this could be the cause?
Throttle signal is ID: 0x01 starting at bit 0 and is 12 bits long.
Any suggestions to what could be the cause would be great. TIA
Savvycan filtered log attached.
Timestamp pot (avg) pot (min) pot (max)
2021-05-01T17:29:45.914 307.98 46 815
2021-05-01T17:29:46.346 318.98 46 816
2021-05-01T17:29:46.901 363.89 47 816
2021-05-01T17:29:47.374 305.3 47 816
2021-05-01T17:29:47.949 303.61 47 815
2021-05-01T17:29:48.781 298.61 46 815
2021-05-01T17:29:49.393 303.68 47 816
2021-05-01T17:29:50.461 308.04 46 815
2021-05-01T17:29:51.127 334.3 47 815
2021-05-01T17:29:51.606 300.23 46 816
2021-05-01T17:29:51.960 338.68 46 816
2021-05-01T17:29:52.283 299.05 47 815
2021-05-01T17:29:52.611 323.53 46 816
2021-05-01T17:29:52.957 354.43 47 816
2021-05-01T17:29:53.284 344.81 46 815
2021-05-01T17:29:53.634 312.58 46 815
2021-05-01T17:29:54.107 346.37 46 816
2021-05-01T17:29:54.624 349.36 46 816
2021-05-01T17:29:55.136 303.73 46 816
2021-05-01T17:29:55.607 356.05 47 816
2021-05-01T17:29:55.932 317.24 44 816
2021-05-01T17:29:56.320 334.45 47 816
2021-05-01T17:29:56.659 301.98 47 815
2021-05-01T17:29:56.999 322.05 46 816
2021-05-01T17:29:57.323 309.82 47 816
2021-05-01T17:29:57.662 340.33 46 815
2021-05-01T17:29:58.001 308.15 46 816
2021-05-01T17:29:58.334 303.31 46 816
2021-05-01T17:29:58.749 320.62 47 815
2021-05-01T17:29:59.350 326.74 46 816
2021-05-01T17:29:59.801 317.21 46 816
2021-05-01T17:30:00.161 331.14 46 816
2021-05-01T17:30:00.525 326.47 47 815
2021-05-01T17:30:00.871 340.23 46 815
2021-05-01T17:30:01.221 329.74 47 816
2021-05-01T17:30:01.757 318.04 47 816
2021-05-01T17:30:02.348 305.3 47 816
2021-05-01T17:30:02.927 345.07 47 816
2021-05-01T17:30:04.067 357.22 46 816
2021-05-01T17:30:04.715 303.76 46 816
2021-05-01T17:30:05.037 326.41 46 815
2021-05-01T17:30:05.370 308.09 46 816
2021-05-01T17:30:05.750 303.6 47 816
2021-05-01T17:30:06.223 331.33 47 816
2021-05-01T17:30:06.708 305.22 46 816
2021-05-01T17:30:07.343 343.39 46 816
2021-05-01T17:30:07.934 365.11 47 816
2021-05-01T17:30:08.266 325.02 47 815
2021-05-01T17:30:08.645 329.82 47 816
2021-05-01T17:30:08.979 311.53 47 816
2021-05-01T17:30:09.427 345.2 47 816
2021-05-01T17:30:09.759 305.63 47 816
2021-05-01T17:30:10.085 347.91 46 815
2021-05-01T17:30:10.460 323.62 47 815
2021-05-01T17:30:10.800 305.22 47 816
2021-05-01T17:30:11.146 307.15 47 816
2021-05-01T17:30:11.486 340.46 47 816
2021-05-01T17:30:12.044 361.74 46 815
2021-05-01T17:30:12.589 317.22 46 816
2021-05-01T17:30:13.211 306.67 47 816
2021-05-01T17:30:13.606 313.29 47 816
2021-05-01T17:30:13.957 331.36 47 816
2021-05-01T17:30:14.525 346.88 47 816
2021-05-01T17:30:15.040 319.06 46 816
2021-05-01T17:30:17.178 311.19 47 815
