Page 1 of 1
AURIS inverter Parallel MG1 and MG2 and DCDC question
Posted: Thu Apr 22, 2021 7:42 pm
by invokeperformance
Hello I just found out I have a Auris gen 3 inverter instead of a Prius. However I have a Prius gen 3 logic board kit. I can drive MG2 no problem and FOC tune. Can I still parallel MG1 and MG2 by connecting the six solder jumpers on the board in the same way as I would with the Prius gen 3 inverter?
Finally for the Auris inverter; in addition to the needed 350V CAP upgrade are the 210k DCDC resistor location values the same as the Prius inverter?
(Prius instructions shown below)
replace 4 resistors on the top side of the board, these are R629, R627, R625, R623, currently 120k ohm, these will need replacing with 210k ohm
Thanks!
Re: AURIS inverter Parallel MG1 and MG2 and DCDC question
Posted: Fri Apr 23, 2021 6:21 am
by bexander
Are you able to fit the Prius logic board in a Auris? To my knowledge the Yaris/Auris logic board is smaller.
Anyway, you should be able to parallel the outputs (MG1 and MG2) in the same way for Prius Gen3, Auris and Yaris inverter.
If I remember correctly the Yaris/Auris DC/DC controller board is different from the Prius Gen3. There are still 4+4pcs of resistors that need to be replaced. They should all be located on the same side. Unfortunately I can't find the instructions on the forum but they should be here somewhere...
Posted: Fri Apr 23, 2021 1:17 pm
bexander wrote: Fri Apr 23, 2021 6:21 am Are you able to fit the Prius logic board in a Auris? To my knowledge the Yaris/Auris logic board is smaller.
Yes the Prius logic board fits in the Arius inverter but not perfect, but all the signal connections can be made.
I am also unable to find the exact resistor change location on the wiki or forum I only need to modify DCDC to handle 360v-380v .
Posted: Fri Apr 23, 2021 5:48 pm
by bexander
Ok, to my knwoledge there is a 11mm difference in length on the logic board between the Prius gen3 and Yaris/Auris inverter.
Maybe the information regarding the resistors for the DC/DC can be found in a video by Damien?
