Prius running on trolley lines (2014)
Posted: Fri Apr 16, 2021 7:03 am
openinverter Community
https://openinverter.org:443/forum/
And I'm screaming: that what buck converters are for!The overhead power lines put out 600 volts at around 400 amps ... The NiMh battery that does the heavy lifting in a normal Prius puts out 273 volts at 6.5 amps. Jon uses up the excess power on a whole lot of resistors
