Page 1 of 1
Nissan Leaf EM61 motor on gen2 inverter?
Posted: Mon Apr 12, 2021 4:17 pm
by PaulHeystee
Anybody knows if I can use the gen1 EM61 motor with gen2 inverter?
Paul
Re: Nissan Leaf EM61 motor on gen2 inverter?
Posted: Mon Apr 12, 2021 4:27 pm
by SciroccoEV
With replacement logic board, yes, I can't see why not.
With CANbus control of inverter, no. The resolver offset needs to be set in the inverter. I don't think the information on how this is done is known.
Posted: Mon Apr 12, 2021 4:35 pm
by PaulHeystee
Thanks!
Posted: Thu Aug 11, 2022 9:51 pm
by Romale
PaulHeystee wrote: ↑Mon Apr 12, 2021 4:17 pm
Paul
100% you can. I have checked it more than once. they have the same resolver set up! for example, when I was making a jaguar xj351, I installed the em61 motor and the inverter from em57 (gen2) and controlled the inverter by can vcu, it drives perfectly! there is only one nuance. you definitely need to connect the extreme phase terminals on the contrary!
Posted: Fri Aug 12, 2022 12:53 am
by paaa
SciroccoEV wrote: ↑Mon Apr 12, 2021 4:27 pm
Dala has figured out the can messages required to set new offset in inverter, think it's on the forum here if if not it on YouTube
Posted: Fri Aug 12, 2022 12:58 pm
by Romale
paaa wrote: ↑Fri Aug 12, 2022 12:53 am
I repeat. there is no need to change the offset. it's the same! only the extreme conclusions of the motor phases are located on the contrary.
Posted: Fri Aug 12, 2022 1:13 pm
by SciroccoEV
Romale wrote: ↑Fri Aug 12, 2022 12:58 pm
Some manufacturers mechanically align their resolvers to the rotor. Nissan don't, but instead measure the offset and laser etch the value onto the motor casing.
When an inverter or motor are changed, you have to MATCH the resolver offset to the inverter. The Nissan service manual is quite clear on the matter.
If the new motor happens to have the same offset as the old motor, then no, no change will be needed.
Just because in your case the offset was the same (or at least close enough), that doesn't mean that anyone else will get away without reprogramming the offset.
Posted: Fri Aug 12, 2022 2:51 pm
by johu
That said, the values we collected here seem to point to rather small differences between motors:
viewtopic.php?t=108
So I guess they will all "run" when interchanged but probably at suboptimal performance or efficiency
Posted: Tue Aug 23, 2022 7:18 am
by dimonlipko
I try this config with OEM invertor, and its work. EM61 and EM57 have same resolver.
Posted: Wed Nov 30, 2022 9:07 pm
by jackro
Hi I'm new at all this and I have a question I hope someone can answer.
I have Gen1 em61 Leaf motor & inverter although they weren't from the same car. I heard somewhere that they may not be compatible for some reason. If that is so, is there a fix?
Could someone clear this up for me?
Jack
Rush NY
Posted: Wed Nov 30, 2022 11:24 pm
by crasbe
Did you find this thread here?
https://openinverter.org/forum/viewtopic.php?t=1895
The procedure for encoding the new resolver offset into the inverter is explained here.
Posted: Sun Feb 19, 2023 12:49 am
by slackerEV
Does the Nissan Leaf EM61 motor also work with Nissan Leaf Gen 3 inverter 160KW ? please kindly advise, thank you.
Posted: Sun Feb 19, 2023 2:59 am
by lsh3rd
Since the gen 3 inverters use the exact same EM57 motors as the gen 2 inverters, even without trying I would confidently say the answer is "yes". Dala the great has been freely swapping the gen 3 inverters to earlier cars and re-writing resolver offsets accordingly. Modern-day hot-rodding at its finest!
