Software 4.59 v1
Posted: Mon May 27, 2019 11:35 am
by Peter
Hi Johannes. As you are aware a few of us are using v1 of the software after removing R21 on Damiens controller board. My question being does the CAN part of the software work in v1? Thought I would ask the guru himself before I start working on the CAN interface. Thanks once again. Peter
Re: Software 4.59 v1
Posted: Mon May 27, 2019 1:49 pm
Yes I only disable parts of the software for a given revision if there are resource conflicts. There is no resource conflict around CAN, so it is always enabled
Posted: Mon May 27, 2019 2:15 pm
by Peter
Thanks you Johannes. Glad it is enabled, my next task is to be able to read and implement the CAN on my Arduino. Keep up the good work. Peter
