OEM Connector Salvaging: Lead Bath
Posted: Sat Feb 06, 2021 3:51 am
by AdvancedEnergySys
Re: OEM Connector Salvaging: Lead Bath
Posted: Sat Feb 06, 2021 8:50 am
Very cool, now you can forego ordering the connectors. Why are they filled with toothpaste or something?
Posted: Sat Feb 06, 2021 4:22 pm
by MattsAwesomeStuff
johu wrote: ↑Sat Feb 06, 2021 8:50 amVery cool, now you can forego ordering the connectors. Why are they filled with toothpaste or something?
So lead doesn't pour into them and freeze?
Blowtorch directly to the board is normally my approach. Skip the middleman.
Posted: Sun Feb 07, 2021 12:11 am
by jon volk
Im more a cast iron skillet on the stovetop guy. Same method Im using for smt assembly
Posted: Sun Feb 07, 2021 9:45 pm
Attempt number 2 started with connectors filled with an oil based clay which ended up melting a bit and being completely unnecessary!
jon volk wrote: ↑Sun Feb 07, 2021 12:11 am
Just make sure you aren't doing this inside, Lead oxide is hard to avoid when in a pan on the stove and once you start breathing it in blood toxicity isn't far behind. That being said, having a molten bath of lead surrounded by snow in a place that snows often isn't much less hazardous.
I only lost a few connectors on my first board with all of the 50 pin connectors coming out perfect!
