Charger Recommendation
Posted: Tue Jan 05, 2021 9:00 pm
by bobbyj_408
Hi All,
I purchased a first gen chevy volt pack for use in a 450h conversion. I realize the pack has a small capacity, but I plan on getting a second pack to help with range.
My question is, what charger do you recommend? It's possible that I can get a hold of the charger from the Volt, but I wanted to get your recommendations. A friend who has converted a vehicle has recommended a Tesla gen 2 charger, but, again, I wanted your thoughts. There are a lot of chargers out there, so what could give me the best bang for buck (keeping budget in mind).
Thanks!
Re: Charger Recommendation
Posted: Tue Jan 05, 2021 10:03 pm
by Bratitude
It’s really up to you. How fast do you want to charger it? How much space do you have available? Are you planing on implementing dc fast charging?
the volt chargers are small, compact units. Same with the outlander. but are 3-6kwh. Tesla gen 2 is 10kwh.
So it really depends on how you want to use your buidl
Posted: Wed Jan 06, 2021 2:28 am
by bobbyj_408
Yeah good points.
How fast? Well yeah I suppose I'd say "as fast as I reasonable can". I am thinking of converting a truck, so there's potential for a lot of space to put the charger need be.
Fast charging? Hmmmm if love to, but what are the options for that? What charger could I use to implement that? FYI, I live in the U.S, so I assume I be using chademo, correct?
Also, for the Tesla charger, what else would I need to get it to work? Do I need to replace the logic board? It'd be great to utilize the on board OEM Volt BMS, could I interface that with the tesla charger (or any other charger).
Posted: Wed Jan 06, 2021 3:07 am
by Bratitude
I suggest reading threw the different sections of the forum. A very large Variety of charging setups people are using!
North America is chademo and ccs. Looks like ccs becoming defacto.
Tesla charger section threads, GitHub, and the wiki will tell you everything
