The joy of Finite State Machines
Posted: Tue Jan 05, 2021 8:48 am
While pondering options for my Vehicle Control Unit, I stumbled across the concept of Finite State Machines. Forgive me if this is already common knowledge, but somehow I missed this in my engineering training...
My worry was that as I added layers of complexity to the VCU, it would get to the point that unexpected things could start to happen. I'm sure we've all struggled to make sense of nested if...then...else statements. At the same time, the concept of a finite state machine was difficult to get my head around (and it seemed unnecessarily complicated). I thought I'd share here what I've learned, in case it's useful for anyone else grappling with the same thing...
Here's a simple example: my bike has a side stand.
When the side stand is down, I want:
It works, but things will get complicated very quickly. Debugging will be a challenge.
Here's the same functionality using the Automaton finite state machine library:
The finite state machine code seems to make much more sense to my simple engineering brain. Plus, you get easy debugging over the serial console.
If you're still unconvinced, check out this fuel gauge example.
If this is useful for anyone, I'll post some more musings as I develop the VCU...
- The side stand light to come on
- The charger to be (conditionally) enabled
- The throttle to be held at zero
- The side stand light to go out
- The charger to be disabled
const int stand_light_pin = LED_BUILTIN; // Use on-board LED
const int stand_switch_pin = 2; // Switch is connected to earth on pin 2
boolean stand_switch_state = false;
void setup() {
pinMode(stand_light_pin, OUTPUT);
pinMode(stand_switch_pin, INPUT_PULLUP);
void loop() {
stand_switch_state = digitalRead(stand_switch_pin);
switch( stand_switch_state) {
case true: digitalWrite(stand_light_pin, HIGH); break;
case false: digitalWrite(stand_light_pin, LOW);
}Here's the same functionality using the Automaton finite state machine library:
#include <Automaton.h>
Atm_led stand_light; // create a LED output machine
Atm_button stand_switch; // create a button input machine
void setup() {
Serial.begin( 115200 ); // for debugging output
stand_light.begin( stand_light_pin ); // start the LED machine
stand_switch.begin( stand_switch_pin ) // start the button machine
.onPress( stand_light, stand_light.EVT_ON ) // send an ON event to the LED machine
.onRelease( stand_light, stand_light.EVT_OFF) // send an OFF event to the LED machine
.trace( Serial ); // log events to serial console
void loop() {
automaton.run();
}If you're still unconvinced, check out this fuel gauge example.
