using v3 with gen3 prius
Posted: Thu Dec 31, 2020 3:11 pm
hi guys, i have been given an unpopulated v3 board as i am unable to get the duel motor board atm, apart from soldering the components to this pcb what else will i need to get my inverter/converter up and running on the bench? my gen3 inverter is bog standard atm as i was hoping to just drop the duel motor board in. what else will i need? i cant find much info on the addition steps required thanks in advance.
