Wanted Siemens Motor
Posted: Wed Dec 23, 2020 9:32 pm
by Colm Spain
HI looking for a Siemens Motor around 120 Hp for a speed boat conversion.
Thanks Colm.
Re: Wanted Siemens Motor
Posted: Thu Dec 24, 2020 10:46 pm
by Bratitude
Where are you located?
Posted: Fri Dec 25, 2020 7:54 pm
by Colm Spain
Hi, I live in Ballina, Co. Tipperary, Ireland on the shores of Lough Derg. What type of motor do you have?
Cheers Colm.
Posted: Sat Dec 26, 2020 12:08 am
by Bratitude
Welp. I’m in Canada, about to pickup 2 semiens 1pv motors from the ev Ford rangers from back in the day.
Posted: Sat Dec 26, 2020 12:08 pm
by Colm Spain
What kw are they? just at the planning stage, I want the boat to plane so need good size motor, I was thinking of 120 Kw. Any ideas on this.
Thanks Colm.
Posted: Sun Dec 27, 2020 5:49 pm
by Bratitude
Colm Spain wrote: ↑Sat Dec 26, 2020 12:08 pm
Thanks Colm.
the inverter you choose will determine the power output. But these motors I think can handle 200kw pushed threw them before heat soak
Posted: Sun Dec 27, 2020 6:16 pm
by Colm Spain
Are you selling one, what price and model no. is it. what inverter would yo recommend.
Thanks Colm.
Posted: Sat Jan 02, 2021 9:03 pm
by Colm Spain
Hi, any update on the motors ?
Posted: Sun Jan 03, 2021 2:24 am
by Bratitude
I’m in Canada, so not sure if worth it to ship.
It’s the classic Siemens ev motor 1PV5133.
I have a gen 3 Prius inverter I’m going to use to drive one.
Posted: Mon Jan 04, 2021 9:18 pm
by Colm Spain
Hi , what price are you looking for the motor and I can check out shipping cost.
Many thanks Colm.
Posted: Sat Jan 09, 2021 5:50 pm
by Bratitude
Colm Spain wrote: ↑Mon Jan 04, 2021 9:18 pm
Many thanks Colm.
Looking for 900 Canadian,
they weight about 200lbs.
And it has a reduction gear box still on it.
Posted: Sun Jan 17, 2021 6:59 pm
by Colm Spain
Hi, the price seems fine , as you said the carriage might be expensive, will check it out, do you know the difference between 1PV5133 and 1PV5135 motors.
Thanks Colm.
Posted: Sun Jan 17, 2021 9:52 pm
by Bratitude
Colm Spain wrote: ↑Sun Jan 17, 2021 6:59 pm
Thanks Colm.
From my understanding the face plate, shaft and bearings are different. As it’s built around the gear box. Other than that they are identical.
There’s quite a bit of miss information on these Siemens motors. power ratting, etc.
But the motor may actually weight around 140lbs
Use without the gear box just requires swapping to sealed bearings.
Posted: Thu Jan 21, 2021 7:42 pm
by Colm Spain
Thanks for the info and pictures, its a pity we don't live closer.
