Several questions about hardware
Posted: Thu May 02, 2019 3:45 pm
Hello all,
I have some questions about the internal analog interfaces (I’m referring to the mainboard version 3 resp. „mainboardv1.1.pdf“)
1) The current measurements are realized with the MLX91205 hall sensors, these are supplied with 5V and have an output voltage of 2.5V at 0A loadcurrent. A first resistor divider (1k2-3k3) is placed on the sense board.
On the mainboard the current signals connect to JP7.6 and JP7.9, followed by an additional resistor divider (3k3-4k7), afterwards they’re routed to the µC (ADC5 / ADC8).
If I calculate / simulate the voltage levels with the combined resistor dividers, I see at the output of the sense board / input of the mainboard a 0A-voltage level of 1.65V. This is almost exactly 3.3V/2 and I would expect this 0A-voltage level also at the ADC inputs of the µC.
But, this voltage is divided once more by the second resistor divider on the mainboard, which results in a 0A-voltage of 970mV. This is rather surprising, particularly because it limits the complete measuring range to 1.94V.
Is the concept really the way it is described? Or do I misunderstand something?
Thanks for your replies,
Fabian.
Fabian.
