Thanks, managed to disable it, it was a little different to Johannes in that I had to change to softcode instead of adaptations.
Changing the second to last value to 3 did it. No Service intervals.
Still got a few more issues to chase on the car errors front but that's one ticked off.
First time charging the car, only left it running 10-15 min for testing. Should be ready for MOT in next week or 2.
Re: VW - Beetle 2003
Posted: Mon Aug 02, 2021 1:14 pm
by ZooKeeper
Very nice! W A Y ahead of me
Posted: Mon Aug 02, 2021 4:30 pm
by Alibro
ZooKeeper wrote: ↑Mon Aug 02, 2021 1:14 pm
And Me, LOL.
Posted: Mon Aug 02, 2021 6:31 pm
by Bigpie
It's still rough and ready and no MOT yet, but if it's usable I can tackle the rest as a series of mini projects to refine. Need ignition on to charge for example.
Posted: Tue Aug 03, 2021 12:56 pm
by ZooKeeper
Bigpie wrote: ↑Mon Aug 02, 2021 6:31 pm
My planned solution is a switch on the fuel door
Posted: Tue Aug 03, 2021 1:09 pm
by JaniK
That is the solution that should be on ICE cars too. No go if charge port/fuel door open.
Posted: Tue Aug 03, 2021 1:15 pm
I use Arduino DUE with a dedicated PP sense pin. When PP is connected to EVSE it will pull to GND and DUE will sense connection and sort out charging, disable the car and start coolant pump. When car is on it will keep DCDC alive and whatever i require. I developed this interface into a version V4.1 where it could even serve as CHADEMO interface. https://leafdriveblog.wordpress.com/202 ... it-module/ https://github.com/arber333/Arduino-Due-CAN-shield
On my previous conversion cable from charge door oxidized and virtually rotted in a year. I dont recommend this route unless you use tinned cable, and still...
Posted: Tue Aug 03, 2021 1:21 pm
by Bigpie
I'm going to use the CP signal with a diode and a IRF520 with a capacitor to switch on a relay to power up the VCU, Simpbms and inverter, with diodes to prevent powering up the rest of the ignition. A comparator for the PP pin for pulling AC present high in SimpBMS.
That's the plan at the minute anyway.
Posted: Mon Aug 09, 2021 6:20 pm
by Bigpie
Well I got insurance with Keith Michaels and had a little test drive.
Posted: Mon Aug 09, 2021 7:09 pm
by ZooKeeper
Beetle (getting some) Juice!! LOL
Posted: Tue Aug 10, 2021 4:52 pm
by Bigpie
It's getting some Beetle Juice now, only at 5 amp for now. Still got a few bugs to squash in my SimpBMS Web interface but it's looking good.
Posted: Thu Aug 12, 2021 11:06 am
by Bigpie
MoT test passed today Got a nice print out of the axle weights too.
Posted: Thu Aug 12, 2021 11:20 am
by rstevens81
Congratulations, now onto the round of continuous improvement that follow
Posted: Thu Aug 12, 2021 12:20 pm
by Bigpie
yes, need to get more 'beans' it needed a push off the rollers.
Posted: Thu Aug 12, 2021 2:53 pm
by ZooKeeper
I thought they were heavier, cool!
Posted: Thu Aug 12, 2021 7:01 pm
by Alibro
Congratulations!
Did you need to pass an inspection or was the MOT enough?
Posted: Thu Aug 12, 2021 7:08 pm
by Bigpie
Just a mot so far. I've had nothing back from DVLA yet.
Posted: Fri Aug 13, 2021 10:20 pm
by Alibro
Bigpie wrote: ↑Thu Aug 12, 2021 7:08 pm
So can you drive it on the road legally?
Posted: Sat Aug 14, 2021 7:06 am
by Bigpie
As far as I know, yes.
Posted: Sat Aug 21, 2021 4:09 pm
by Bigpie
Longest trip to date, 16 miles round trip, with 56% battery remaining according to bms. Just over 4100mv to 3665mv. Didn't quite have the umph to reverse up my mum's steep driveway, I think I'll have to parallel MG1 and MG2 maybe.
Posted: Sat Aug 21, 2021 5:43 pm
by Ev8
What have you set your lower cell voltage limit to in simpbms? First time out I was showing 50% battery at 3.5v but the bmw modules seem to start falling of the cliff at 3.4v so be careful until you work out where your modules are actually happy being drawn down to!
Posted: Sat Aug 21, 2021 6:33 pm
by Bigpie
From memory I've got 100% at 4100 and 10% at 3200. I'll bare that in mind though when testing. I've got a tesla shunt to put in there so will be able to measure in and out better.
Posted: Sat Aug 21, 2021 6:58 pm
by m.art.y
Bigpie wrote: ↑Sat Aug 21, 2021 4:09 pm
What you got set as throtcur? I've noticed on my car with gen3 prius inverter that in reverse it has less power than going forward. I think power might be limited in that direction on purpose.
Posted: Sat Aug 21, 2021 7:32 pm
by Bigpie
I'm using reverse gear and not flipping the motor direction. I have throtcur at 3.6 and that sometimes gets me overcurrent cutouts (toyota forced)
