Teensy 3.2 based CAN controller/vcu [SOLD]
Posted: Sat Oct 24, 2020 1:41 pm
Unlike Damien, I don’t have ambitions of retiring to Lanzarote, but looking to put a small dent in the cost of having to replace my drive unit. I put together a small and simple board that can function as a minimal add on CAN VCU. Board requires a Teensy 3.2 and has a CAN transceiver, 3 analog inputs, and 3 ground switched outputs. Boards will come fully soldered along with the required mating Molex connector and terminals.
Since it runs a 3.2, one could also port Tom’s BMS code over if you were looking for something in a sealed enclosure. I don’t utilize all the same inputs and outputs so those would need to be reassigned if you were looking to go that route.
I have some basic code up on GitHub for running LDU parameters over CAN in repo LDU_CAN https://github.com/jonvolk . Some use cases for analog ins would be throttle and brake pressure in order to do some preliminary processing in the Teensy and controlling those inputs to the inverter over CAN or use the outputs for driving analog gauges, water pump or fan relays, etc.
$245 shipped international
$225 shipped US
I have 4 boards immediately available, but will probably keep 1 for my own use.
$225 shipped US
