VW Polo 86C High Voltage Conversion
Posted: Fri Apr 12, 2019 5:31 pm
So, for completeness sake I'll repeat the Polo conversion here, the mother of all "Another Homebrew AC controller" conversions :)
  • 152 LFP040AH in series for an idle voltage of ~500V
  • 18.5kW Industrial ACIM (Lenze MFEMAXX132-22C1C)
  • Homebrew AC controller (using 1200V, 400A IGBTs)
  • Homebrew BMS
  • Inverter Charging
  • LiFePo4 System battery charged by an ebay AC/DC (no DC/DC converter)
  • Audi vacuum pump (8E0927317) for braking with Audi pressure sensor (036906051G) and homebrew control electronics (some resistors, an NPN transistor and a relay)
  • Heating element from a 230Vac heater with a custom solid state relay
  • 800V, 16mm² "solar cable" for the DC connections
  • 4x6mm² for the motor connection
  • Lots of wood, aluminum and fibreglass
I have kept as many original components as possible. For example the original throttle had a pot already, so I could use that. I added another rear defroster switch for cruise control and a pot that controls max regen torque.
I use the existing temperature and fuel gauge as well as the warning lights. Reverse gear is selected with the transmission.
Kilometers driven to date: 25.000km
