Files uploaded fine but now I can't get the web interface to load in my browser. I've tried restarting the inverter but no change. Wifi is ok so only the web interface thats not ok.
This is what comes up when trying to acces web interface:
Any way I can fix this without removing the wifi module from the inverter?
Re: Failed to update web interface
Posted: Sat Sep 26, 2020 1:37 am
by dima
It looks like you uploaded something not from index.html but some github page?
2) Install Arduino SPIFFS Uploader plug-in
3) Move all web-interface data into a "data" folder except "FSBrowser.ino"
4) Open FSBrowser.ino
5) Do "Sketch Data Upload"
Yes that will fix it. Curl exists for windows also
Posted: Sat Sep 26, 2020 5:52 am
by bexander
Thank you dima and johu!
Fixed using curl.
My mistake was that I didn't download the files correctly from github, instead I saved the source which resulted in the html of the webpage and not the intended file. Next time I will check the html file before I upload it.
Posted: Sun Oct 04, 2020 9:40 am
by james@N52E01
I'm about to do the same procedure, I have "index.js" and "index.html" from the link provided on the Inverter Firmware v4.90.R thread. Hopefully no issue there.
Can I add a further question to this thread please as it may be related? I also plan to update to v4.90.R using FOC, the web interface updater says: Use binary files (stm32sine_HWCONFIG_XXX.bin) for updating inverter firmware. Upload any other file for updating this web interface.
I couldn't find any file titled stm32sine_HWCONFIG_....bin or similar in the github repository for v4.90.R. Am I looking in the wrong place or for the wrong file or just blind
Posted: Sun Oct 04, 2020 12:10 pm
by bexander
The example text (stm32sine_HWCONFIG_XXX.bin) is just telling you to use the .bin files.
Use the stm32_foc.bin from the 4.90 release and you should be good.
Posted: Sun Oct 04, 2020 12:34 pm
by james@N52E01
Brilliant, thanks bexander will give that a go
Posted: Fri Oct 09, 2020 9:30 am
by james@N52E01
Just loaded the new firmware and updated the web interface, worked absolutely fine
