Page 4 of 8
Re: HOWTO: Flashing ESP8266
Posted: Wed Apr 29, 2020 3:29 pm
by dima
ZooKeeper wrote: ↑Tue Apr 28, 2020 8:02 pm
Yup, thanks!! Olimex on the way so I have enough memory, apparently the ESP-01 does not
You can try removing not essential files from /Data folder.
gauge.min.js.gz
gauges.html
gauges.js
Posted: Thu Apr 30, 2020 6:20 pm
by jnsaff
So I solved this issue by soldering a new board and making sure I get a blue pill with a genuine STM32. Which of them was the actual culprit I don't know, but now I have the parameters in the web interface and everything works out of the box.
I know for sure that the first Blue Pills came with clone stm32 chips. I also can't rule out dodgy soldering first time round.
jnsaff wrote: ↑Mon Mar 16, 2020 9:20 pm
I'm having a similar problem as well. I got the ESP8266 from Johannes so it should be fine. Then programmed the bootloader and stm32_sine.hex red led is on and green is blinking on the blue pill.
No parameters are showing but when I try to Display Error Memory I get:
Unknown command sequence
e��K�
Custom command 'json' gets
So it seems that they are communicating as from the forum search this error is something that the stm32_sine sends back. But TX may be messed up somehow? I believe my Blue Pills may be quite dodgy .. so would want to put the black pill on there instead but the pin labels are not exactly the same. Any ideas? Much appreciated!
Posted: Sat May 02, 2020 6:50 pm
by ZooKeeper
post deleted
Posted: Sat May 02, 2020 9:32 pm
by ZooKeeper
post deleted
Posted: Sun May 03, 2020 4:04 pm
by ZooKeeper
post deleted
Posted: Sun May 03, 2020 4:47 pm
by SciroccoEV
Have you clicked on refresh?
Posted: Sun May 03, 2020 7:28 pm
by MattsAwesomeStuff
Are any of the LEDs on the blue pill blinking, or are they on solidly?
Posted: Sun May 03, 2020 10:34 pm
by ZooKeeper
post deleted
Posted: Mon May 04, 2020 12:31 am
ZooKeeper wrote: ↑Sun May 03, 2020 10:34 pmBluePill & Olimex have solid red LEDs
I bet you made the same mistake I did. There is supposed to be a blinking LED if you flash the firmware successfully.
Did you flash the bootloader file before you flashed the SINE or FOC file?
See my failures (and the previous forum page), if that's true:
viewtopic.php?p=5760#p5760
Posted: Mon May 04, 2020 2:25 am
by ZooKeeper
post deleted
Posted: Tue May 05, 2020 12:51 am
TX goes to RX.
RX goes to TX.
Maybe try rebooting them.
Other than that I'm coming up blank.
Posted: Tue May 05, 2020 4:26 am
by Isaac96
How about serial link speed?
If you were to connect a USB/TTL converter then you could check the serial link speeds, and see if any data shows up. The STM32 sends "2D" upon powerup or reset, and if you send 'json' it should spit out lots of stuff. Newline character is required.
I believe my STM32 talks at 115200baud (although my ESP died rather randomly and exhibits similar symptoms) so that could be a good starting point.
I will need to work on a ESP for myself soon enough. Best of luck in the meantime!
-Isaac
Posted: Tue May 05, 2020 2:26 pm
by ZooKeeper
post deleted
Posted: Tue May 05, 2020 9:43 pm
Hmm, I'm not sure I'm much help past this point because I didn't use the Olimex board.
What's your procedure you're following, and where is it failing or not getting results?
Posted: Wed May 06, 2020 4:01 pm
by dima
I can suggest to "put on your programmer's hat on" and try to troubleshoot beyond ESP. Try to connect TX/RX directly into USB-TTL dongle (CH340/PL2303 ...of course with proper drivers installed). Open "putty"
https://the.earth.li/~sgtatham/putty/la ... taller.msi and see if you can connect to Blue-Pill (selecting right COM and speed)
Posted: Fri May 08, 2020 3:43 pm
by ZooKeeper
post deleted
Posted: Wed May 13, 2020 7:26 pm
by davidwagstaff
ZooKeeper wrote: ↑Sat May 02, 2020 9:32 pm
UPDATE: After trying the available memory size options, I finally got everything to load!!!! Sill "FileNotFound" @ 192.168.4.1 however... UGH
Yet ANOTHER update..... SUCCESS!!!!!!!!
I have the same issue. Using Olimex Mod and Arduino IDE to flash. All seems to go ok but on the 192.168.4.1 page I get "file not found". What did you do to fix this?
Posted: Wed May 13, 2020 8:22 pm
I have a feeling this is one of those things where the instructions either aren't being followed, or, aren't correct for the very first time someone sets something up.
Else, a procedure should work exactly the same for everyone.
David - What procedure are you following? Link to it so we can know exactly what you did.
Getting File not Found when you go to the IP doesn't tell us much troubleshooting-wise other than that there's nothing at that IP. This could be because you did literally nothing, or that you got 99% of the way.
It could be something as simple as, you're connected to the wifi in your home rather than connecting to the ESP8266. You haven't given us anything to help you with.
Posted: Thu May 14, 2020 8:26 am
by davidwagstaff
Thanks for your reply Matt.
I have a Olimex Mod board and been trying to program with the Arduino IDE . I've got the boards loaded in the IDE. I've connected the board to USP-TTL as per instructions on page 1, moved solder bridge to 0.
Created folders with ino and data. as per arbers instructions on page 3.
If I open the ino file and with the correct board and port selected I can program the Olimex, everything appears ok. It gets to resetting the board and just sits there.
Then I've tried either waiting a while and trying the ESP data upload tool or manually resetting the board by powering it down and then trying. Either way it appears to load the SPIFF and gives completed messages.
I'll try again and take some screen shots.
Posted: Thu May 14, 2020 12:06 pm
by davidwagstaff
- FS Browser.PNG (8.03 KiB) Viewed 24501 times
This is the output screen from Arduino IDE.
Sketch uses 356800 bytes (34%) of program storage space. Maximum is 1044464 bytes.
Global variables use 28496 bytes (34%) of dynamic memory, leaving 53424 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.6
2.6
esptool.py v2.6
Serial port COM11
Connecting....
Chip is ESP8266EX
Features: WiFi
MAC: 5c:cf:7f:8d:b8:d3
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 512000
Changed.
Configuring flash size...
Auto-detected Flash size: 2MB
Compressed 360960 bytes to 255263...
Writing at 0x00000000... (6 %)
Writing at 0x00004000... (12 %)
Writing at 0x00008000... (18 %)
Writing at 0x0000c000... (25 %)
Writing at 0x00010000... (31 %)
Writing at 0x00014000... (37 %)
Writing at 0x00018000... (43 %)
Writing at 0x0001c000... (50 %)
Writing at 0x00020000... (56 %)
Writing at 0x00024000... (62 %)
Writing at 0x00028000... (68 %)
Writing at 0x0002c000... (75 %)
Writing at 0x00030000... (81 %)
Writing at 0x00034000... (87 %)
Writing at 0x00038000... (93 %)
Writing at 0x0003c000... (100 %)
Wrote 360960 bytes (255263 compressed) at 0x00000000 in 5.4 seconds (effective 531.5 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
[SPIFFS] data : C:\FSB\FSBrowser\data
[SPIFFS] size : 1004
[SPIFFS] page : 256
[SPIFFS] block : 8192
/ajax-loader.gif
/chart.min.js.gz
/gauge.min.js.gz
/gauges.html
/gauges.js
/index.html
/index.js
/inverter.js
/log.html
/log.js
/README.md
/refresh.png
/style.css
/wifi-updated.html
/wifi.html
[SPIFFS] upload : C:\Users\David\AppData\Local\Temp\arduino_build_792348/FSBrowser.spiffs.bin
[SPIFFS] address : 0x100000
[SPIFFS] reset : ck
[SPIFFS] port : COM11
[SPIFFS] speed : 512000
[SPIFFS] python : python3.exe
[SPIFFS] uploader : C:\Users\David\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\tools\upload.py
Then on my phone I am changing to the ESP wifi and attempting to go to 192.168.1.4 and get "FileNotFound"
Posted: Thu May 14, 2020 4:14 pm
by dima
All debug looks good, steps followed correctly. Maybe there is a bug with URL "/"?
Perhaps try full URL? ->
http://192.168.4.1/index.html
Posted: Thu May 14, 2020 5:56 pm
And I'll just reitterate... on whatever device you're using to access the 8266, you're connecting to its wifi, not your home wifi, right? Could be a firewall issue too on your side.
What are you using to connect? Desktop, laptop, tablet, phone?
Posted: Fri May 15, 2020 6:40 am
by davidwagstaff
Yes Matt, I'm Connecting to the ESP wifi Via my iphone.
If I just try going to 192.168.4.1 without changing wifi I get site cannot be reached errors so definitely on the ESP.
Are there any files I've missed in the SPIFFS load?
Posted: Fri May 15, 2020 10:34 am
by davidwagstaff
Ok tried it on a Wemos Node Mcu Lolin and it is the same. must be something i'm missing.
Had a play with the ino code to see if I can debug. Changed the 2 "file not found" messages to "filenotfound1" and "filenotfound2"
Now i'm getting a file not found 1 message when I try to access webpage.
Posted: Fri May 15, 2020 2:49 pm
by dima
Did you set maximum SPIFFS size?
- arduino-esp-spiffs-max.png (9.64 KiB) Viewed 24398 times
Why not try command line?
Need these tools:
Build
mkspiffs.exe -c C:\FSB\FSBrowser\Data\ -b 8192 -p 256 -s 600000 flash-spiffs.bin
Flash
python esptool.py --port COM1 --baud 115200 write_flash 0x100000 flash-spiffs.bin
