Page 4 of 21
Posted: Fri Jul 24, 2020 9:37 am
by Kevin Sharpe
Jack Bauer wrote: ↑Fri Jul 24, 2020 7:54 am
Will be a few weeks before I have the E39 kitted out with a Chademo "exhaust" for testing. If anyone else is going to get there quicker and willing to help with testing,I'll donate a leaf vcu.
I can probably help in a few weeks if no one else is ready.
I'm making a CHAdeMO to CCS adaptor which in it's first iteration could simply bypass the CCS functionality. We could also jury rig a CHAdeMO interface into the bus directly for testing
Posted: Fri Jul 24, 2020 3:56 pm
by Isaac96
Working perfectly (at least on the bench). Added this line to Setup() to give a heartbeat led : pinMode(13, OUTPUT); //led
Will be a few weeks before I have the E39 kitted out with a Chademo "exhaust" for testing. If anyone else is going to get there quicker and willing to help with testing,I'll donate a leaf vcu. In the meantime I'll get my wifi guy to do some wifi firmware so we can have a display ready to go.
Isaac96, if you are happy I'll throw this up on Github?
Yup, go ahead. I've checked through the code a couple times now, all seems correct.
I can probably start testing Chademo in a couple of days (with my different hardware) but first I have to get a shunt hooked up and add a few CAN messages (only in my version) to get voltage readings.
The Chademo stations will probably not be happy if my voltage readings are too far off... My custom BMS has quite a slow sample rate (it's talking to 12 different things at 9600, one at a time) so I might have to add some hacks to make that work.
-Isaac
Posted: Fri Jul 24, 2020 4:11 pm
by arturk
I have car ready to test it and all other components except Leaf VCU...
Posted: Fri Jul 24, 2020 9:14 pm
by mcgousha
I must have been working in IT projects for too long, I really enjoyed reading through the last couple of days on this thread.
Fantastic collaboration happening here. Big kudos to Isaac96 for stepping up to the plate and sharing his skills.
I'll throw my hat into the ring as a potential tester (assuming it's still needed) as soon as I have the battery installed in the Porsche, I have a Leaf Chademo port just waiting to be put back to use.
Posted: Fri Jul 24, 2020 10:55 pm
by Isaac96
I'm doing some bench testing... Some very weird things happening.
I am testing with my GEVCU hardware, so pins 48-51 are usable as inputs.
For some reason 48 and 50 don't work with the rest of the Chademo code. When read by a simple DigitalReadSerial they read the inputs just fine but when the Chademo code is set to use them, no readings (they stay high).
I'm fairly sure this is caused by some of the libraries in use but don't have the time right now to test all that properly.
The problem here is that the Leaf VCU uses pins 49 and 48 as outputs, so I don't know if those will work, and can't fully test the output side.
(48 and 50 don't appear to work as outputs, 49 and 51 probably do work).
Yes, I'm very confused. Going to set off to the local Chademo station and see if the init sequence is acceptable at the altar of EVGo.
-Isaac
Posted: Sat Jul 25, 2020 12:58 am
by Isaac96
I think the inputs are reading correctly. However, the charger is timing out.
IN1 gets pulled high by the station, the car begins sending CAN, then the station shuts down with a 'communication error'.
I'm going to test CAN more properly -- it certainly receives properly, but I may or may not have reversed the wiring, and haven't tested sending yet.
Getting close to full communication though.
-Isaac
Posted: Sat Jul 25, 2020 11:20 am
Excellent work and thanks everyone for offers of assistance.
Posted: Sat Jul 25, 2020 10:11 pm
by Isaac96
Thanks for the kind words guys, it's not quite there yet though.
Found the issue with pins 48/50 - the due_can library defaults to using them for CAN enable.
So I'm setting the CAN enable pins to 255 (which nulls them out).
ISA.h also needed changes since it also defaults to 48/50. Modified version is attached.
(That library is weird, it seems to autosave/autorecover amp-hours on power reset. No idea if that works, I don't have an ISA shunt yet).
I also seem to have forgotten that the CAN mailboxes needed to be set up -- I just added that in along with a little more debugging (since there are plenty of bugs).
v0.4 is attached.
I'm going off for another test at the station. I do hope it works this time, it's such a pain to move the whole setup.
Note - when there's a 1.0 release I'd like to include copies of all the libraries, since at least one will end up modded and that's no fun for anyone else.
-Isaac
Posted: Sat Jul 25, 2020 10:45 pm
by Isaac96
Went out for a test run, one station was in use by a Bolt and the other has a dead credit card reader...
I'll try again in an hour or so.
-Isaac
Posted: Sun Jul 26, 2020 12:08 am
by mdrobnak
Isaac96 wrote: ↑Sat Jul 25, 2020 10:11 pm
Glad to see you've got that mostly going.
The auto save/recover is to try and compute accurate State of Health or Charge. Not sure which.
I didn't realize CAN mailboxes were "a thing" in most micro-controllers.. I have definitely have seen them on ST C167 16-bit processors. (Bosch ME 7.5/7.8 ECUs)
Isaac96 wrote: ↑Sat Jul 25, 2020 10:45 pm
-Isaac
How, like, 90s man. Don't you know apps are the future?
-Matt
Posted: Sun Jul 26, 2020 12:30 am
by Isaac96
mdrobnak wrote: ↑Sun Jul 26, 2020 12:08 am
Most microcontrollers with inbuilt CAN seem to have them -- SAM3X, Teensy (Freescale/NXP ARM chips). I don't know how to use them, just zeroed them all out
-Matt
Well, yes, but it's not exactly easy to run an app on a $30 flip phone
CHAdeMO is not the future either -- Nissan has abandoned it on the new Ariya.
-Isaac
Posted: Sun Jul 26, 2020 3:49 am
by Isaac96
I finally beat the CAN issues (I think) and the station tried to start charging! (No battery connected meant it threw a voltage mismatch fairly quickly, but at least it got that far). Contactors fired correctly too. I need to get an ISA shunt (more likely to just use one of my spare LEM HTFS sensors).
In other news, anyone got a spare Leaf contactor? I may or may not have previously fried a couple while previously working on my car, and I need one more for Chademo. Willing to pay of course - a pair runs $90 on eBay.
-Isaac
Posted: Sun Jul 26, 2020 7:52 am
Isaac, shoot me a pm. I have a few contactors here and I'll throw in a leaf vcu. Sadly I don't have a spare ISA shunt as they are all in my cars. Will have to try and arrange a few more.
Posted: Sun Jul 26, 2020 11:13 am
by Cookie6000
mcgousha wrote: ↑Fri Jul 24, 2020 9:14 pm
Same here. I'm very close to having the battery full in plus have a Chademo port ready to go. Will just need to order another Leaf board so more than willing to test.
Posted: Mon Jul 27, 2020 9:57 am
Here is a first draft of a dedicated Chademo controller based on the Leaf VCU. Would appreciate it if people took a look over to see if (where) I have screwed up.
-Deleted unused pins and components.
-Added two onboard relays. RLY1 activates 12v feed to the vcu when chademo plug is inserted. RLY2 controls the HV contactors.
-Added pullup to IN1.
-Vehicle connections via the 12way connector. Chademo signals via the 20 way.
Want to keep it as simple and universal as possible so please don't ask me to add support for steering cruise missiles etc.
Posted: Mon Jul 27, 2020 5:02 pm
by Isaac96
Looks good to me. It also makes me wonder whether my pin assignments are correct in the v0.4 code - they're in globals.h.
IN1 and IN0 may be reversed, would you mind checking that out? For that matter OUT0 and OUT1 might be backwards too. I think I set those according to the first VCU wiring diagram you put up.
Also, how should OUT3 be integrated into the software? I'm not sure what you're planning to use it for.
-Isaac
Posted: Tue Jul 28, 2020 6:35 am
So I want OUT3 to activate when hv is required and de activate when charging finishes. Yeah I've changed a few things around on this design but no need to worry about that right now. We'll just get it running on the leaf vcu then can adapt.
Posted: Tue Jul 28, 2020 6:41 am
by Isaac96
Jack Bauer wrote: ↑Tue Jul 28, 2020 6:35 am
Alright, I'll look at the code and see where that could fit. Is it intended to power up a contactor system?
-Isaac
Posted: Tue Jul 28, 2020 7:05 am
Yeah its just a HV request signal if that makes sense.
Posted: Fri Jul 31, 2020 6:31 pm
by Isaac96
CHAdeMO VCU from Damien arrived today! Thank you so much!!!
I'll have it wired up in an hour or so and go try it out (just waiting on ISA shunt, that should be here soon enough).
At least I can see how CAN works and whether I set up the I/O correctly.
HV request - that will be in the next version after I've verified correct operation.
-Isaac
Posted: Fri Jul 31, 2020 9:59 pm
by Isaac96
Isaac96 wrote: ↑Fri Jul 31, 2020 6:31 pm
-Isaac
So it's been a little more than an hour. I've got the VCU mostly wired up now.
But IN2 has a 1K5 pulldown (part of the voltage divider) which is being annoying (I think I have a 10K, far too weak).
I see on the schematic for the future CHAdeMO VCU that has been changed to a pullup, so I'll probably do the same on this Leaf VCU.
Pin names have been changed to reflect the hardware better, v0.5 is coming after some testing @ station with HV request added.
-Isaac
Posted: Sat Aug 01, 2020 4:17 am
by Isaac96
Looks like Leaf VCU communicates correctly.
Charge shuts down (after closing contactors) because I still have neither batteries nor shunt hooked up, but that should all still work.
v0.5 is attached, with HV request added.
Also edited this wiring diagram to reflect the new wiring.
Anyone else with Leaf VCU, you might want to remove R17 (1k5 pulldown on IN2) if you don't have other plans for the VCU. If not I suppose a buffer or optocoupler might work.
-Isaac
Posted: Sat Aug 01, 2020 6:57 am
Fantastic. Will be able to test in the E39 in a few weeks. Thanks as always:)
Posted: Fri Aug 07, 2020 2:27 pm
by mfox
This is great . I also want to make chademo on my BMW.
Max system voltage is 220V .
As I can see all this is adjustable
Posted: Fri Aug 07, 2020 5:50 pm
by Kevin Sharpe
mfox wrote: ↑Fri Aug 07, 2020 2:27 pm
Some CHAdeMO rapid chargers do not support low voltage operation (see Damien's test videos from a few years ago). We don't know how widespread this problem is so you will be on the 'bleeding edge' for sure
