Re: Webasto HVH50
Posted: Tue Feb 27, 2024 2:02 pm
HA! Yes. I am not sure what ID is the write ID though, so I guess I can modify the code to run through all IDs 0-64 . . .
#include "lin_bus.h"
// Create an IntervalTimer object
IntervalTimer myTimer;
int ledState = LOW; // ledState used to set the LED
unsigned long interval = 200000; // interval at which to blinkLED to run every 0.2 seconds
LIN lin;
int lin_cs = 32; // cs and serial port set for skpang LIN / FDCAN board
int led1 = 23;
int lin_fault = 28;
uint16_t Power = 1000; // set to required power
uint8_t Temperature = 100; //set to required temperature
uint16_t tmpheater = 0;
uint16_t udcheater = 0;
uint16_t powerheater = 0;
uint8_t CRC = 0;
uint8_t orderID = 0;
//uint8_t responseID = 0;
uint8_t data[8];
void setup() {
pinMode(LED_BUILTIN, OUTPUT);
pinMode(lin_fault,INPUT);
pinMode(lin_cs, OUTPUT);
digitalWrite(lin_cs, HIGH); // enable MCP2004 LIN transceiver
digitalWrite(LED_BUILTIN, HIGH);
Serial.begin(115200);
//Serial.print("HVH50 Heater demo");
//lin.begin(&Serial3, 9600);
lin.begin(&Serial3, 19200); /// Change to this for 19200 /////
delay(1000);
pinMode(led1,OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
myTimer.begin(blinkLED, interval);
void loop() {
// heater
SendLin();
delay(1000); // wait 1000ms
//Serial.print(" Heater test\n");
void blinkLED() {
ledState = !ledState;
digitalWrite(LED_BUILTIN, ledState);
digitalWrite(led1, ledState);
static void SendLin()
for (orderID = 0; orderID < 64; orderID++) {
static bool read = true;
uint8_t data[8];
uint8_t lindata[] = {uint8_t(Power/40), uint8_t(Temperature+40), 0, 8};
lin.order(orderID, lindata, 4, lin2x);
delay(100);
if (lin.response(39, data, 8, lin2x) >=0) // -1 indicates crc error, 19200
tmpheater = data[1] - 40;
udcheater = data[4] | (data[5] & 3) << 8;
powerheater =((data[5] >> 2) | (data[6] << 8)) * 20;
Serial.print("orderID:");
Serial.print(orderID);
Serial.print(",");
Serial.print("Temp:");
Serial.print(tmpheater);
Serial.print(",");
Serial.print("Udc:");
Serial.print(udcheater);
Serial.print(",");
Serial.print("Power:");
Serial.println(powerheater);
Serial.print("CRC:");
Serial.print(CRC);
Serial.print(",");
else if (read)
else
//Serial.print("\n Sending power and temperature");
read = !read;
}Code: Select all
CRC:0,orderID:0,Temp:21,Udc:60,Power:400
CRC:0,orderID:1,Temp:21,Udc:60,Power:400
CRC:0,orderID:2,Temp:21,Udc:60,Power:400
CRC:0,orderID:3,Temp:21,Udc:60,Power:400
CRC:0,orderID:4,Temp:21,Udc:60,Power:400
CRC:0,orderID:5,Temp:21,Udc:60,Power:400
CRC:0,orderID:6,Temp:21,Udc:60,Power:400
CRC:0,orderID:7,Temp:21,Udc:60,Power:400
CRC:0,orderID:8,Temp:21,Udc:60,Power:400
CRC:0,orderID:9,Temp:21,Udc:60,Power:400
CRC:0,orderID:10,Temp:21,Udc:60,Power:400
CRC:0,orderID:11,Temp:21,Udc:60,Power:400
CRC:0,orderID:12,Temp:21,Udc:60,Power:400
CRC:0,orderID:13,Temp:21,Udc:60,Power:400
CRC:0,orderID:14,Temp:21,Udc:60,Power:400
CRC:0,orderID:15,Temp:21,Udc:60,Power:400
CRC:0,orderID:16,Temp:21,Udc:60,Power:400
CRC:0,orderID:17,Temp:21,Udc:60,Power:400
CRC:0,orderID:18,Temp:21,Udc:60,Power:400
CRC:0,orderID:19,Temp:21,Udc:60,Power:400
CRC:0,orderID:20,Temp:21,Udc:60,Power:400
CRC:0,orderID:21,Temp:21,Udc:60,Power:400
CRC:0,orderID:22,Temp:21,Udc:60,Power:400
CRC:0,orderID:23,Temp:21,Udc:60,Power:1040
CRC:0,orderID:24,Temp:21,Udc:60,Power:400
CRC:0,orderID:25,Temp:21,Udc:60,Power:400
CRC:0,orderID:26,Temp:21,Udc:60,Power:400
CRC:0,orderID:27,Temp:21,Udc:60,Power:400
CRC:0,orderID:28,Temp:21,Udc:60,Power:400
CRC:0,orderID:29,Temp:21,Udc:60,Power:400
CRC:0,orderID:30,Temp:21,Udc:60,Power:400
CRC:0,orderID:31,Temp:21,Udc:60,Power:400
CRC:0,orderID:32,Temp:21,Udc:60,Power:400
CRC:0,orderID:33,Temp:21,Udc:60,Power:400
CRC:0,orderID:34,Temp:21,Udc:60,Power:400
CRC:0,orderID:35,Temp:21,Udc:60,Power:400
CRC:0,orderID:36,Temp:21,Udc:60,Power:400
CRC:0,orderID:37,Temp:21,Udc:60,Power:400
CRC:0,orderID:38,Temp:21,Udc:60,Power:400
CRC:0,orderID:39,Temp:21,Udc:60,Power:1040
CRC:0,orderID:40,Temp:21,Udc:60,Power:400
CRC:0,orderID:41,Temp:21,Udc:60,Power:400
CRC:0,orderID:42,Temp:21,Udc:60,Power:400
CRC:0,orderID:43,Temp:21,Udc:60,Power:400
CRC:0,orderID:44,Temp:21,Udc:60,Power:400
CRC:0,orderID:45,Temp:21,Udc:60,Power:400
CRC:0,orderID:46,Temp:21,Udc:60,Power:400
CRC:0,orderID:47,Temp:21,Udc:60,Power:400
CRC:0,orderID:48,Temp:21,Udc:60,Power:400
CRC:0,orderID:49,Temp:21,Udc:60,Power:400
CRC:0,orderID:50,Temp:21,Udc:60,Power:400
CRC:0,orderID:51,Temp:21,Udc:60,Power:400
CRC:0,orderID:52,Temp:21,Udc:60,Power:400
CRC:0,orderID:53,Temp:21,Udc:60,Power:400
CRC:0,orderID:54,Temp:21,Udc:60,Power:400
CRC:0,orderID:55,Temp:21,Udc:60,Power:400
CRC:0,orderID:56,Temp:21,Udc:60,Power:400
CRC:0,orderID:57,Temp:21,Udc:60,Power:400
CRC:0,orderID:58,Temp:21,Udc:60,Power:400
CRC:0,orderID:59,Temp:21,Udc:60,Power:400
CRC:0,orderID:60,Temp:21,Udc:60,Power:1040
CRC:0,orderID:61,Temp:21,Udc:60,Power:400
CRC:0,orderID:62,Temp:21,Udc:60,Power:400
CRC:0,orderID:63,Temp:21,Udc:60,Power:400
61,0,0,61,192,0,100,1
61,0,0,60,192,0,100,0
61,0,0,60,192,0,100,1
61,0,0,60,192,0,101,0
61,0,0,61,192,0,99,1
61,0,0,61,192,0,99,0
61,0,0,60,192,0,101,1
Status
4=running
Outlet temp
Scaling as above
Inlet temp -
Voltage LSB
Voltage MSB - 2 bits
Power LSB - 6 bits / Power MSB 1 digit=20W
UnknownCode: Select all
59, 0, 114, 58, 64,0, 239, 0Code: Select all
LIN lin;
int led1 = 23;
int lin_fault = 28;
uint16_t Power = 40; // set to required power
uint8_t Temperature = 85; //set to required temperature
uint8_t CRC = 0;
//uint8_t data[8];
uint8_t linTXdata[4] = { 0, 0, 0, 0 }; // 40W, 45C, heater on
uint8_t linRXdata[8] = { 0, 0, 0, 0, 0, 0, 0, 0 };
//uint8_t CRC = 0;
//uint8_t orderID = 0;
void setup() {
delay(1000);
void loop() {
// heater
SendLin();
delay(100); // wait 100ms
void blinkLED() {
uint8_t data[8];
lin.order(34, linTXdata, 4, lin2x);
delay(100);
CRC = lin.response(39, linRXdata, 8, lin2x);
lin.response(39, linRXdata, 8, lin2x); //>=0) // -1 indicates crc error, 19200
tmpheater = linRXdata[1] - 40;
udcheater = linRXdata[4] | (linRXdata[5] & 3) << 8;
powerheater =((linRXdata[5] >> 2) | (linRXdata[6] << 8)) * 20;
//Serial.print("orderID:");
//Serial.print(orderID);
//Serial.print(",");
Serial.print(",");
Serial.print(",");
Serial.println(CRC);
Serial.print(linRXdata[0]);
Serial.print(",");
Serial.print(linRXdata[1]);
Serial.print(",");
Serial.print(linRXdata[2]);
Serial.print(",");
Serial.print(",");
Serial.print(linRXdata[4]);
Serial.print(",");
Serial.print(linRXdata[5]);
Serial.print(",");
Serial.print(linRXdata[6]);
Serial.print(",");
Serial.print(linRXdata[7]);
Serial.print(",");
Serial.println(linRXdata[8]);
//Serial.println(data);
//else if (read)
// else
//uint8_t linTXdata[] = {uint8_t(Power/40), uint8_t(Temperature+40), 0, 8};
read = !read;
orderID:30,Temp:19,Udc:58,Power:320
CRC:0
0,59,0,0,58,64,0,238,27
orderID:31,Temp:19,Udc:58,Power:320
CRC:0
orderID:32,Temp:19,Udc:58,Power:320
CRC:0
0,59,0,0,58,64,0,237,27
orderID:33,Temp:19,Udc:58,Power:320
CRC:0
orderID:34,Temp:19,Udc:58,Power:320
CRC:0
0,59,0,0,58,64,0,239,27
orderID:35,Temp:19,Udc:58,Power:320
CRC:0
128,59,0,0,58,64,0,110,27
orderID:36,Temp:19,Udc:58,Power:320
CRC:0
orderID:37,Temp:19,Udc:58,Power:320
CRC:0
0,59,0,0,58,64,0,237,27Code: Select all
LIN lin;
uint16_t Power = 400; // set to required power
int lin_cs = 32; // pin 23 for my LIN board
int led1 = 23;
int lin_fault = 28;
uint8_t linTXdata[4] = { Power, Temperature, 0, 8 }; // 40W, 45C, heater on
uint8_t CRC = 0;
void setup() {
pinMode(lin_fault, INPUT);
lin.begin(&Serial3, 19200); // or
delay(1000);
pinMode(led1, OUTPUT);
void loop() {
//for (orderID = 0; orderID < 64; orderID++) {
//for (responseID = 0; responseID < 64; responseID++) {
delay(100);
delay(100);
Serial.print(34, HEX);
Serial.print("\t");
Serial.print(39, HEX);
Serial.print("\t");
Serial.println(CRC, HEX);
for (int i = 0; i < 8; i++) { // display the raw data
Serial.print(linRXdata[i]);
Serial.print("\t");
Serial.print("\t");
Serial.print(" ");
Serial.println();
delay(10);
128
95
2
116
91
80
0
22
22 27 0
128
95
2
114
91
80
0
24
22 27 0
32
95
0
114
91
80
0
122
22 27 0
32
95
0
115
91
80
0
121
22 27 0
32
89
0
117
89
80
0
127
22 27 0
32
88
0
115
88
80
0
131
22 27 0
32
84
0
116
83
80
0
139
22 27 0
32
84
0
115
83
80
0
140
22 27 0
32
82
0
116
81
80
0
143
22 27 0
32
82
0
115
81
80
0
144
22 27 0
32
80
0
116
80
80
0
146
22 27 0
32
80
0
116
79
80
0
147
22 27 0
32
79
0
116
78
80
0
149
22 27 0
32
79
0
115
78
80
0
150
If that is the case, do I need to change it from 8 to 16? The heater can handle up to 5000W on the HVH50 and 7000W on the HVH70.
I will do this for sure and let you know.
No, the simplist way it to put the code back to how it was originally with the power sent over LIN the required power / 40.jsimonkeller wrote: ↑Mon Mar 04, 2024 4:58 am If I use the max 8 bit value of 255, by the formula of (255-256)*40 = -40, right???
CRC:0
0,59,0,115,58,64,0,237,27
CRC:0
0,59,0,115,58,64,0,239,27
CRC:0
128,59,0,115,58,64,0,110,27
CRC:0
0,59,0,115,58,64,0,237,27Code: Select all
Node_attributes {
HVH_100{
LIN_protocol = "2.0" ;
configured_NAD = 0x5F ;
product_id = 0x0, 0x0, 0 ;
response_error = PTC_ResponseError ;
P2_min = 10 ms ;
ST_min = 10 ms ;
configurable_frames {
HV_He_01 = 0x401C ;
HV_Hs_01 = 0x4030 ;
HV_Hs_02 = 0x400C ;Code: Select all
Frames {
HV_He_01: 28, Controller, 4 {
KL_HV_PTC_soll, 0 ;
KL_PTC_ein, 8 ;
H
V_Hs_01: 48, HVH_100, 8 {
PTC_HV_I_ist, 0 ;
PTC_HV_ERR, 8 ;
PTC_HV_Status_PTC, 16 ;
PTC_Status_UBatt, 19 ;
PTC_ResponseError, 21 ;
PTC_TimeOut_Fehler, 22 ;
PTC_HV_Err_Heizkreis_1, 24 ;
PTC_HV_Err_Heizkreis_2, 25 ;
PTC_HV_Err_Heizkreis_3, 26 ;
PTC_HV_Err_Leckagestrom, 27 ;
PTC_HV_Err_Ueberstromabschaltung, 28 ;
PTC_HV_Err_Temperaturschutz, 29 ;
PTC_HV_Err_intern, 30 ;
PTC_UBatt, 32 ;
PTC_Temp_PCB, 40 ;
PTC_HV_Heizmedium_Sensor_1, 48 ;
PTC_HV_Heizmedium_Sensor_2, 56 ;
HV_Hs_02: 12, HVH_100, 8 {
HVH_HV_Voltage, 32 ;
HVH_HV_Voltage_Offset, 41 ;
HVH_HV_Ilock_Status, 45 ;
HVH_ParameterChange, 61 ;
HVH_ErrMem_State, 62 ;
Schedule_tables {
ST1 {
HV_He_01 delay 20 ms ;
HV_Hs_01 delay 20 ms ;
HV_Hs_02 delay 20 ms ;
DiagRequest {
MasterReq delay 10 ms ;
DiagResponse {
SlaveResp delay 10 ms ;
Just so you know, I did this as well a while back. Here is a photo of the board. I purchased an extra heater at a good price that was sold without warranty it was functioning. I opened in up and started checking for continuity and I was able to identify some of the pathways, such as the HVIL loop and the 12V line pathway to a dead end after the resistor at a small black chip (circled below), which might be the gateway that opens when the proper LIN command is received. I assume this could be bypassed, but I abandoned this in favor of learning how to program the LIN with a sealed unit. I also discovered that there is a GND wire in the 8 wire setup (#8) that I started using with the board outside of the metal case, just to make sure the board was getting a good GND signal. I actually got some sparks with the 12v only attached when the multimeter prong touched across a couple of lines accidentally. I agree that there should be a way to bypass the lockout of 12V on and off that is closed in programming.
uint16_t requestedpower = 0;
uint16_t actualpower = 0;
uint16_t inwatertemp = 0;
uint16_t outwatertemp = 0;
uint16_t lowvoltage = 0;
uint16_t currentconsumption = 0;
LIN lin;
int led1 = 23; // sk pang board builtin led
int lin_fault = 28;
uint8_t CRC = 0;
void setup() {
//Serial.print("Heater demo");
lin.begin(&Serial3, 19200);// Baud Rate for the SR02-2 Heater
void loop() {
// heater
SendLin();
void blinkLED() {
//static bool read = true;
uint8_t data[8];
// read ID27 register
lin.response(0x27, data, 7, lin2x); //
delay(10);
// write ID33 register
uint8_t lindata0[] = { 0x00, 0x10 }; // chechksum 0, counter 0, HvCooltHeatrEnadWhE2EHvchEnad = 1 which is 0x10 Hex
lin.order(0x33, lindata0, 2, lin2x);
delay(10);
// write ID22 register again, HvWtrHeatrPwrCnsAllwd = 6000W based on top voltage of 350V for my car
uint8_t lindata2[] = { 0x96, 0x78, 0xFF, 0xD0 }; // 6000w power, 80C target temp, max flow, enable
lin.order(0x22, lindata2, 4, lin2x);
delay(10);
// read ID17 register
lin.response(0x17, data, 3, lin2x); // we need 10+10 bits according to spec, so request 3 bytes
requestedpower = data[1] * 20;//(20w/bit) offset
actualpower = data[0] * 20;//(20w/bit) offset
Serial.print("RequestedPower:");
Serial.print(requestedpower);
Serial.println(",");
Serial.print("ActualPower:");
Serial.print(actualpower);
Serial.println("");
lin.response(0x27, data, 7, lin2x); // we need 56 bits according to spec, so request 7 bytes
inwatertemp = data[4];//(1℃/bit) offset
outwatertemp = data[1];//(1℃/bit) offset
lowvoltage = data[3] / 10;//(0.1V/bit) offset
currentconsumption = data[2] / 4;//(0.25A/bit) offset
Serial.print("WaterTempIn:");
Serial.print(inwatertemp);
Serial.print("WaterTempOut:");
Serial.print(outwatertemp);
Serial.print("CurrentConsumption:");
Serial.print(currentconsumption);
Serial.print("LowVoltageReading:");
Serial.print(lowvoltage);
Serial.println("");
Serial.println("");
delay(500);
RequestedPower:3520,
ActualPower:320
WaterTempIn:61,
WaterTempOut:61,
CurrentConsumption:1,
LowVoltageReading:13
RequestedPower:3680,
ActualPower:2180
WaterTempIn:120,
WaterTempOut:122,
CurrentConsumption:6,
RequestedPower:1280,
ActualPower:1580
WaterTempIn:123,
WaterTempOut:124,
CurrentConsumption:4,
RequestedPower:4000,
ActualPower:980
WaterTempIn:126,
WaterTempOut:127,
CurrentConsumption:3,
LowVoltageReading:12
UDS-Diagnosis
The standard LIN 2.1 Diagnosis frames (see LDF file Frame ID 0x3C / 0x3D) will be used to map Universal Diagnosis. Services / Sub-Services and Data.
