Page 4 of 4
Re: Any driveability quirks/complaints?
Posted: Sat May 01, 2021 8:24 am
by arber333
johu wrote: ↑Sat May 01, 2021 7:55 am
Been asked for many times. I suggest someone with a Toyota inverter tries it first
Maybe I can try to keep the basic slip calculation and just replace V/f by FOC? Hmm.
I volunteer my Mazda for testbed
I use gen2 boards modified for Volt inverter. I have Lacrosse ACIM motor here with resolver. I also have straight gen2 inverter in Mazda and it works with AB encoder. So i am able to test both versions. Also if you insist i can make Mazda work with single channel encoder.
Posted: Sat May 01, 2021 12:10 pm
by jon volk
Took the car out for a thrashing this morning with the recent upload and did not experience any elastic throttle feel. I could push hard on the regen into a corner and power out with no transition delay.
Posted: Sat May 01, 2021 12:17 pm
by Jack Bauer
I have a gen 3 prius inverter and Siemens 1pv5135 in the E39 so happy to test foc. Mr.Toyota won't let anyting silly happen...
Posted: Sat May 01, 2021 1:01 pm
by Boxster EV
jon volk wrote: ↑Sat May 01, 2021 12:10 pm
Just tried it - Elastic has gone - Fantastic.
Posted: Sat May 15, 2021 7:02 am
by Jack Bauer
The Panzer is now running the latest VolkSoft(tm) firmware. About to head out out on a voyage...
Posted: Tue Aug 24, 2021 5:52 pm
by johu
I've tried adding the Volk mods to the latest software, can somebody test whether I succeeded?
Diff is here:
https://github.com/jsphuebner/stm32-sin ... e6ac39730a
Posted: Tue Aug 24, 2021 6:34 pm
by arber333
Hex please... i will just go around the block
Posted: Tue Aug 24, 2021 10:30 pm
by jon volk
Let the personal injury claims begin.
Posted: Wed Aug 25, 2021 5:15 pm
by Boxster EV
I’ll give this a try when back from holiday next week
Posted: Wed Aug 25, 2021 5:29 pm
by arber333
johu wrote: ↑Tue Aug 24, 2021 5:52 pm
Johu, can you post .hex file so i can load it to Mazda asap? Bin doesnt work for me. Tnx
Posted: Wed Aug 25, 2021 6:24 pm
by johu
Here you go.
Posted: Wed Aug 25, 2021 8:31 pm
by joromy
Is the Volk mods for tesla only, or can I use it on any acim?
Posted: Thu Aug 26, 2021 12:22 pm
by jon volk
Should be applicable to any acim motor as its just a modification of the fweak value at low throttle inputs. Theres a parameter added to adjust. If this function is not desired, then that value just gets set equal to fweak.
Posted: Sat Aug 28, 2021 11:39 am
by arber333
Well traction is very good and i am satisfied. But there seem to be no regen present. Not for throttle release or for brake signal. Even though i have it set to -60% in code. Is it possible you changed orientation of your math?
tnx
Posted: Sun Aug 29, 2021 2:14 am
by jon volk
Maybe try bumping it up more? I noticed the higher fweak did reduce regen, but it was a matter of readjusting parameters for me.
Posted: Sun Aug 29, 2021 6:13 am
by johu
Will check in code as well
Posted: Fri Sep 10, 2021 3:54 pm
by jon volk
Curious if there was any further feedback on Johu's integration. I have not tried that file since my own setup has been running flawlessly and Im terrified to change anything haha.
